| aaa |
Enables and configures logging of the following authentication,
authorization, and accounting related events:
- radius-discon-msg –
RADIUS disconnection message
- radius-session-expired
– RADIUS session expired message
- radius-session-not-started – RADIUS session not started message
- radius-vlan-update –
RADIUS VLAN update message
| adapt |
Enables and configures logging of the following adaptivity module
related events:
- adaptivity-change –
Event adaptivity change
- adaptivity-rehome –
Event adaptivity rehome
| adopt-services |
Enables and configures the logging of adopted services related
events |
| adv-wips |
Enables and configures the logging of advanced WIPS related
events |
| ap |
Enables and configures logging of the following AP related events:
- adopted – Event AP
adopted
- adopted-to-controller
– Event AP adopted to wireless controller
- ap-adopted – Event
access port adopted
- ap-autoup-done – Event
AP autoup done
- ap-autoup-fail – Event
AP autoup fail
- ap-autoup-needed –
Event AP autoup needed
- ap-autoup-no-need –
Event AP autoup not needed
- ap-autoup-reboot –
Event AP autoup reboot
- ap-autoup-timeout –
Event AP autoup timeout
- ap-autoup-ver – Event
AP autoup version
- ap-reset-detected –
Event access port reset detected
- ap-reset-request –
Event access port user requested reset
- ap-timeout – Event
access port timed out
- ap-unadopted – Event
access port unadopted
- image-parse-failure –
Event image parse failure
- legacy-auto-update –
Event legacy auto update
- no-image-file – Event
no image file
- offline – Event AP
detected as offline
- online – Event offline
AP detected as online
- reset – Event reset
- sw-conn-lost – Event
software connection lost
- unadopted – Event
unadopted
| bt |
Enables and configures logging of the following bluetooth related
events:
- bt-started – Event
bluetooth (bt) started
- bt-state-change –
Event bt state change
| captive-portal |
Enables and configures logging of the following captive portal (hotspot)
related events:
- allow-access – Event
client allowed access
- auth-failed – Event
client authentication failed
- auth-success – Event
client authentication success
- client-disconnect –
Event client disconnected
- client-removed – Event
client removed
- data-limit-exceed –
Event client data limit exceeded
- flex-log-access –
Event flexible log access granted to client
- inactivity-timeout –
Event client time-out due to inactivity
- page-cre-failed –
Event page creation failure
- purge-client – Event
client purged
- session-timeout –
Event session timeout
- vlan-switch – Event
client switched VLAN
| cdp |
Enables and configures logging of the following CISCO Discovery
Protocol (CDP) related event:
- duplex-mismatch –
Event duplex mismatch detected between CDP neighbors
| certmgr |
Enables and configures logging of the following certificate manager
related events:
- ca-cert-actions-failure – Event CA certificate actions failure
- ca-cert-actions-success – Event CA certificate actions success
- ca-key-actions-failure
– Event CA key actions failure
- ca-key-actions-success
– Event CA key actions success
- cert-expiry – Event
certificate expiry
- crl-actions-failure –
Event Certificate Revocation List (CRL ) actions failure
- crl-actions-success –
Event CRL actions success
- csr-export-failure –
Event CSR export failure
- csr-export-success –
Event CSR export success
- delete-trustpoint-action – Event delete trustpoint action
- export-trustpoint –
Event trustpoint exported
- import-trustpoint –
Event trustpoint imported
- rsa-key-actions-failure – Event RSA key actions failure
- rsa-key-actions-success – Event RSA key actions success
- svr-cert-actions-success – Event server certificate actions success
- svr-cert-actions-failure – Event server certificate actions failure
| certmgr-lite |
Enables and configures logging of certificate manager (lite version)
related event messages |
| cfgd |
Enables and configures logging of the following configuration daemon
module related events:
- acl-attached-altered –
Event Access List (ACL) attached altered
- acl-rule-altered –
Event ACL rule altered
| cluster |
Enables and configures logging of the following cluster module related
events:
- cmaster-cfg-update-fail – Event cluster master config update
failed
- max-exceeded – Event
maximum cluster count exceeded
- state-change – Event
cluster state change (active/inactive)
- state-change-active –
Event cluster state change to active
- state-change-inactive
– Event cluster state change to inactive
- state-retain-active –
Event cluster state retained as active
| crm |
Enables and configures logging of the following Critical Resource
Monitoring (CRM) related event
- critical-resource-down
– Event critical resource goes down
- critical-resource-up –
Event critical resource comes up
| device |
Enables and configures the logging of device module related
events |
| database |
Enables and configures logging of the following error conditions in the
captive-portal/NSIght database:
- database-election-fail
– Event primary database node selection failure. Requires manual
intervention to select primary database node.
- database-exception –
Event database may need to be dropped and device restarted
- database-low-disk-space – Event database low disk space
- database-new-state –
Event database state change
- database-op-failure –
Event database failure
- database-set-name-mismatch – Event replica-set not enabled on
host
- database-storage-mismatch – Event database mismatch. All database
files must be removed.
- operation-complete –
Event database operation completed successfully
- operation-failed –
Event database operation failure
| dhcpsvr |
Enables and configures logging of the following DHCP server related
events:
- dhcp-start – Event
DHCP server started
- dhcpsvr-stop – Event
DHCP sever stopped
- relay-iface-no-ip –
Event no IP address on DHCP relay interface
- relay-no-iface – Event
no interface for DHCP relay
- relay-start – Event
relay agent started
- relay-stop – Event
DHCP relay agent stopped
| diag |
Enables and configures logging of the following diagnostics module
related events:
- autogen-tech-sprt –
Event autogen technical support
- buf-usage – Event
buffer usage
- cpu-load – Event CPU
load
- cpu-usage-too-high –
Event CPU usage high
- cpu-usage-too-high-recovery – Event recovery from high CPU usage
- disk-usage – Event
disk usage
- elapsed-time – Event
elapsed time
- fan-underspeed – Event
fan underspeed
- fd-count – Event
forward count
- free-flash-disk –
Event free flash disk
- free-flash-inodes –
Event free flash inodes
- free-nvram-disk –
Event free nvram disk
- free-nvram-inodes –
Event free nvram inodes
- free-ram – Event free
ram
- free-ram-disk – Event
free ram disk
- free-ram-inodes –
Event free ram inodes
- head-cache-usage –
Event head cache usage
- high-temp – Event high
temp
- ip-dest-usage – Event
ip destination usage
- led-identify – Event
led identify
- low-temp – Event low
temp
- mem-usage-too-high –
Event memory usage high
- mem-usage-too-high-recovery – Event recovery from high memory usage
- new-led-state – Event
new led state
- over-temp – Event over
temp
- over-voltage – Event
over voltage
- poe-init-fail – Event
PoE init fail
- poe-power-level –
Event PoE power level
- poe-read-fail – Event
PoE read fail
- poe-state-change –
Event PoE state change
- pwrsply-fail – Event
failure of power supply
- raid-degraded – Event
Redundant Array of Independent Disks (RAID) degraded
- raid-error – Event
RAID error
- ram-usage – Event ram
usage
- under-voltage – Event
under voltage
- wd-reset-sys – Event
wd reset system
- wd-state-change –
Event wd state change
| dot11 |
Enables and configures logging of the following 802.11 management module
related events:
- client-assoc-ignored –
Wireless client association ignored event
- client-associated –
Wireless client associated event
- client-denied-assoc –
Event client denied association
- client-disassociated –
Wireless client disassociated
- country-code – Event
country code applied
- country-code-error –
Event country code error
- eap-cached-keys –
Event Extensible Authentication Protocol (EAP) cached keys
- eap-client-timeout –
Event EAP client timeout
- eap-failed – Event EAP
failed
- eap-opp-cached-keys –
Event EAP opp cached keys
- eap-preauth-client-timeout – Event EAP pre authentication client
timeout
- eap-preauth-failed –
Event EAP pre authentication failed
- eap-preauth-server-timeout – Event EAP pre authentication server
timeout
- eap-preauth-success –
Event EAP pre authentication success
- eap-server-timeout –
Event EAP server timeout
- eap-success – Event
EAP success
- ft-roam-success –
Event client fast BSS transition
- gal-rx-request – Event
GAL request received event
- gal-tx-response –
Event response sent to GAL request
- gal-validate-failed –
Event GAL validation failed
- gal-validate-req –
Event GAL validation request
- gal-validate-success –
Event GAL validation success
- kerberos-client-success – Event client Kerberos authentication
success
- kerberos-wlan-failed –
Event WLAN Kerberos authentication failed
- kerberos-wlan-success
– Event WLAN Kerberos authentication success
- kerberos-wlan-timeout
– Event Kerberos authentication timed out
- move-operation-success
– Event move operation success
- tkip-cntrmeas-end –
Event TKIP countermeasures ended
- tkip-cntrmeas-start –
Event TKIP countermeasures initiated
- tkip-mic-fail-report –
Event TKIP MIC failure report
- tkip-mic-failure –
Event TKIP MIC check failed
- neighbor-denied-assoc
– Event neighbor denied association
- unsanctioned-ap-active
– Event unsanctioned AP active
- unsanctioned-ap-inactive – Event unsanctioned AP inactive
- unsanctioned-ap-status-change – Event unsanctioned AP status
change
- voice-call-completed –
Event voice call completed
- voice-call-established
– Event voice call established
- voice-call-failed –
Event voice call failed
- wlan-time-access-disable – Event WLAN disabled by time-based-access
- wlan-time-access-enable – Event WLAN re-enabled by time-based-access
- wpa-wpa2-failed –
Event WPA-WPA2 failed
- wpa-wpa2-key-rotn –
Event WPA-WPA2 key rotn
- wpa-wpa2-success –
Event WPA-WPA2 success
| dot1x |
Enables and configures logging of the following 802.1X authentication
related events:
- dot1x-failed – Event
EAP authentication failure
- dot1x-success – Event
dot1x-success
| fa |
Enables and configures logging of fabric attach
related events:
- fa-accepted – Event fa-accepted
- fa-pending – Event fa-pending
| fwu |
Enables and configures logging of the following firmware update
(FWU) related events:
- fwuaborted – Event fwu
aborted
- fwubadconfig – Event
fwu aborted due to bad config
- fwucorruptedfile –
Event fwu aborted due to corrupted file
- fwucouldntgetfile –
Event fwu aborted because the system could not get file
- fwudone – Event fwu
done
- fwufileundef – Event
fwu aborted due to file undefined
- fwunoneed – Event fwu
no need
- fwuprodmismatch –
Event fwu aborted due to product mismatch
- fwuserverundef – Event
fwu aborted due to server undefined
- fwuserverunreachable –
Event fwu aborted due to server unreachable
- fwusignmismatch –
Event fwu aborted due to signature mismatch
- fwusyserr – Event fwu
aborted due to system error
- fwuunsupportedhw –
Event fwu aborted due to unsupported hardware
- fwuunsupportedmodelnum
– Event fwu aborted due to unsupported FIPS model number
- fwuvermismatch – Event
fwu aborted due to version mismatch
| isdn |
Configures file Integrated Service Digital Network (ISDN) module
related event s
- isdn-alert – Event
ISDN alert
- isdn-crit – Event ISDN
critical
- isdn-debug – Event
ISDN debug
- isdn-emerg – Event
ISDN emergency
- isdn-err – Event ISDN
error
- isdn-info – Event ISDN
info
- isdn-notice – Event
ISDN notice
- isdn-warning – Event
ISDN warning
| l2gre |
Enables and configures logging of the following Layer 2 GRE
(L2GRE) tunnel related events:
- l2gre-tunnel-down –
Event L2GRE tunnel down
- l2gre-tunnel-failover
– Event L2GRE tunnel failover
- l2gre-tunnel-up –
Event L2GRE tunnel up
| l2tpv3 |
Enables and configures logging of the following Layer 2 TPV3
(L2TPv3) tunnel related events:
- l2tpv3-tunnel-down –
Event L2TPv3 tunnel down
- l2tpv3-tunnel-up –
Event L2TPv3 tunnel up
| licmgr |
Enables and configures logging of the following license manager module
related events:
- lic-installed-count –
Event total number of license installed count
- lic-installed-default
– Event default license installation
- lic-installed – Event
license installed
- lic-invalid – Event
license installation failed
- lic-removed – Event
license removed
| lldp |
Enables and configures logging of the following Link Layer Discovery
Protocol (LLDP) related events:
- lldp-loop-detected –
Event layer 2 switching loop
- lldp-loop-recovery –
Event recovery from layer 2 switching loop
| mgmt |
Enables and configures logging of the following management services
- log-http-init – Event
Web server started
- log-http-local-start –
Event Web server started in local mode
- log-http-start – Event
Web server started in external mode
- log-https-start –
Event secure Web server started
- log-https-wait – Event
waiting for Web server to start
- log-key-deleted –
Event RSA key associated with SSH is deleted
- log-key-restored –
Event RSA key associated with SSH is added
- log-trustpoint-deleted
– Event trustpoint associated with HTTPS is deleted
| mesh |
Enables and configures logging of the following mesh module related
events:
- mesh-link-down – Event
mesh link down
- mesh-link-up – Event
mesh link up
- meshpoint-down – Event
meshpoint down
- meshpoint-loop-prevent-off – Event meshpoint loop prevent off
- meshpoint-loop-prevent-on – Event meshpoint loop prevent on
- meshpoint-path-change
– Event meshpoint-path-change
- meshpoint-root-change
– Event meshpoint-root-change
- meshpoint-up – Event
meshpoint up
| nsm |
Configures Network Service Module (NSM) related event
- dhcpc-err – Event DHCP
certification error
- dhcpdefrt – Event DHCP
defrt
- dhcpip – Event DHCP IP
- dhcpipchg – Event DHCP
IP change
- dhcpipnoadd – Event
DHCP IP overlaps static IP address
- dhcplsexp – Event DHCP
lease expiry
- dhcpnak – Event DHCP
server returned DHCP NAK response
- dhcpnodefrt – Event
interface no default route
- if-failback – Event
interface failback
- if-failover – Event
interface failover
- ifdown – Event
interface down
- ifipcfg – Event
interface IP config
- ifup – Event interface
up
- nsm-ntp – Event
translate host name
| pm |
Configures process monitor module related event s
- procid – Event proc ID
generated
- procmaxrstrt – Event
proc max restart
- procnoresp – Event
proc no response
- procrstrt – Event proc
restart
- procstart – Event proc
start
- procstop – Event proc
stop
- procsysrstrt – Event
proc system restart
- startupcomplete –
Event startup complete
| radconf |
Enables and configures logging of the following RADIUS configuration
daemon related events:
- could-not-stop-radius
– Event could not stop RADIUS server
- radiusdstart – Event
RADIUS server started
- radiusdstop – Event
RADIUS server stopped
| radio |
Enables and configures logging of the following radio module related
events:
- acs-scan-complete –
Event ACS scan completed
- acs-scan-started –
Event ACS scan started
- cb-associated – Event
client-bridge access point associates with an infrastructure access
point
- cb-roam – Event
client-bridge access point roams from one infrastructure access point
to another infrastructure access point
- cb-wired-client-added
– Event wired client is added to the client-bridge
- cb-wired-client-removed – Event wired client is removed from the
client-bridge
- channel-country-mismatch – Event channel and country of operation
mismatch
- radar-det-info –
Detected radar info
- radar-detected – Event
radar detected
- radar-scan-completed –
Event radar scan completed
- radar-scan-started –
Event radar scan started
- radio-antenna-error –
Event invalid antenna type on this radio
- radio-antenna-setting
– Event antenna type setting on this radio
- radio-state-change –
Event radio state change
- resume-home-channel –
Event resume home channel
| rasst |
Enables and configures the logging of roaming assist module related
events |
| smrt |
Enables and configures logging of the following SMART RF module related
events:
- calibration-done –
Event calibration done
- calibration-started –
Event calibration started
- channel-change – Event
channel change
- config-cleared –
Configuration cleared event
- cov-hole-recovery –
Event coverage hole recovery
- cov-hole-recovery-done
– Event coverage hole recovery done
- interference-recovery
– Event interference recovery
- neighbor-recovery –
Event neighbor recovery
- power-adjustment –
Event power adjustment
- root-recovery – Event
meshpoint root recovery
| smtpnot |
Enables and configures logging of the following SMTP module related
events:
- cfg – Event cfg
- cfginc – Event cfg inc
- net – Event net
- proto – Event proto
- smtpauth – Event SMTP
authentication
- smtperr – Event SMTP
error
- smtpinfo – Event SMTP
information
| system |
Enables and configures logging of the following system module related
events:
- clock-reset – Event
clock reset
- cold-start – Event
cold start
- config-commit – Event
configuration commit
- config-revision –
Event config-revision done
- devup-rfd-fail – Event
device-upgrade failed on rf-domain manager managed devices
- guest-user-exp – Event
guest user purging
- http-err – Event Web
server did not start
- login – Event
successful login
- login-fail – Event
login fail. Occurs when user authentication fails.
- login-fail-access –
Event login fail access. Occurs in case of access violation.
- login-fail-bad-role –
Event login fail bad role. Occurs when user uses an invalid role to
logon.
- login-lockout – Event
user account locked out message. Occurs when a user account is locked
due to exceeding of maximum number failed login attempts threshold.
Configure this event notification only if the max-fail and
lockout-time parameters have been configured in the management-policy
context. For more information, see password-entry.
- login-unlocked – Event
user account un-locked. Occurs when a locked user account is
re-activated. Enable this event notification only if the max-fail and
- logout – Event logout
- maat-light – Event
action on RIM (Research in Motion) radio(s) from the Maat
light module
- panic – Event panic
- periodic-heart-beat –
Event periodic heart beat
stop
- server-unreachable –
Event server-unreachable
- system-autoup-disable
– Event system autoup disable
- system-autoup-enable –
Event system autoup enable
- t5-config-error –
Event t5-config-error
- ui-user-auth-fail –
Event user authentication fail
- ui-user-auth-success –
Event user authentication success
- warm-start – Event
warm start
- warm-start-recover –
Event recovery from warm start
| test |
Enables and configures logging of the following test module related
events:
- testalert – Event test
alert
- testargs – Event test
arguments
- testcrit – Event test
critical
- testdebug – Event test
debug
- testemerg – Event test
emergency
- testerr – Event test
error
- testinfo – Event test
information
- testnotice – Event
test notice
- testwarn – Event test
warning
| vrrp |
Enables and configures logging of the following Virtual Router
Redundancy Protocol (VRRP) related events:
- vrrp-monitor-change –
Event VRRP monitor link state change
- vrrp-state-change –
Event VRRP state transition
- vrrp-vip-subnet-mismatch – Event VRRP IP not overlapping with an
interface addresses
| webf |
Enables and configures logging of the following Web Filtering (webf)
- malform-url-request –
Event malformed URL request
- no-parent-engine –
Event ‘no session to URL classification server‘
- srvr-connect-fail –
Event URL classification server unreachable
- url-blocked – Event
URL blocked
- webf-lic-acquired –
Event webf license acquired
- webf-lic-missing –
Event webf license missing
- webf-lic-revoked –
Event webf license revoked
| wips |
Wireless IPS module related events:
- air-termination-active – Event air termination
active
air-termination-ended – Event air
termination
ended
air-termination-inactive – Event
air termination
inactive
air-termination-initiated –
initiated
rogue-ap-active – Event rogue
AP active
rogue-ap-inactive – Event rogue
AP inactive
unsanctioned-ap-active –
active
unsanctioned AP
inactive
Event unsanctioned AP changed
state
wips-client-blacklisted – Event
WIPS client blacklisted
- wips-client-rem-blacklist – Event WIPS client rem
blacklist
- wips-event – Event WIPS event triggered
Note: Air-termination is not supported on AP505 and
AP510 model access points.
| email |
Sends e-mail notifications to a pre configured e-mail ID |
| forward-to-switch |
Forwards the messages to an external server |
| snmp |
Logs an SNMP event |
| syslog |
Logs an event to syslog |
| default |
Performs the default action for the event |
| off |
Switches the event off, when the event happens, and no action is
performed |
| on |
Switches the event on, when the event happens, and the configured action
is taken |
