The following updates have been made in Revision AB of this guide.
| Updates | Description |
| ap-id (iot-device-type-imagotag-policy) | Added command |
| channel (iot-device-type-imagotag-policy) | Updated to include Imagotag enhancements |
| bridge | Updated supported APs |
References to APs that are no longer supported have been removed througout this guide where supported platforms are specified. These are AP7522, AP7532, AP7562, and AP8432.
The following new features have been added in Revision AA of this guide.
| Topic | Feature Description |
| Added the Operational-mode xiq-cloud command to reset supported Universal APs to factory settings, thereby facilitating migration of ExtremeWireless WiNG locally-managed APs to ExtremeCloud IQ managed APs. | |
| smart-sensor | Added support for AP5010 radio-share mode on R1 to support 6 GHz AP neighbor selection and auto-provisioning of sensors. |
The following updates have been made in Revision AA of this guide.
| Topic | Update Description |
| path-method (meshpoint-device-config) | Added VMM support with AP5010 2.4 GHz and 5 GHz radios |
| rf-mode | Added support for 6 GHz WLAN configuration |
| Corrections and updates to GRE Concentrator description |
