enforce-version
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
         enforce-version [adoption|cluster] [full|major|minor|none|strict]
      Parameters
                     | adoption |
                     Verifies
                        firmware versions before adopting. This option is enabled by
                        default. |
                     | cluster |
                     Verifies
                        firmware versions before clustering. This option is enabled by
                        default. |
                     | full |
                     Allows adoption
                        or clustering when the first four octets of the firmware versions match (for
                        example 5.9.3.0) |
                     | major |
                     Allows adoption
                        or clustering when the first two octets of the firmware versions match (for
                        example 5.9) |
                     | minor |
                     Allows adoption
                        or clustering when the first three octets of the firmware versions match
                        (for example 5.9.3) |
                     | none |
                     Allows adoption
                        or clustering between any firmware versions |
                     | strict |
                     Allows adoption
                        or clustering only when firmware versions exactly match (for example
                        5.9.3.0-010D). This is the default setting for both ‘adoption‘ and ‘cluster‘
                        options. |
nx9500-6C8809(config-profile-test-nx5500)#enforce-version cluster full
nx9500-6C8809(config-profile-test-nx5500)#enforce-version adoption major
nx9500-6C8809(config-profile-test-nx5500)#show context
profile nx5500 test-nx5500
 no autoinstall configuration
 no autoinstall firmware
 crypto ikev1 policy ikev1-default
  isakmp-proposal default encryption aes-256 group 2 hash sha
interface pppoe1
 use firewall-policy default
 service pm sys-restart
 router ospf
 router bgp
 dot1x system-auth-control
 dot1x use aaa-policy OnBoarding
      Related Commands
                     | no |
                     Disables or reverts settings to their default |
