cache-max-recs
    Configures the maximum number of records
      (URL and Web page classification entries) cached in the local database
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
    Syntax
      cache-max-recs <1-1000000>
    Parameters
              | cache-max-recs <1-1000000> |
              Specify the maximum number of records cached in the
                local database from 1 - 1000000.When configuring this value take into
                  consideration the type of device using the Web Filter policy. The value should
                  approximately be as per the following information:
                    - NX95XX – <1-1000000> (default is 100000)
                    - NX75XX – <1-100000> (default is 10000)
                    - RFS Switches – <1-10000> (default is 1000)
                    - Access Points – <1-1500> (default is 500)
      nx9500-6C8809(config-web-filter-policy-test)#cache-max-recs 9000
      nx9500-6C8809(config-web-filter-policy-test)#show context
web-filter-policy test
 cache-max-recs 9000
