| custom-scan |
              Configures the custom-scan channel frequency, channel width, and scan
                weight |
              | channel-frequency <CHANNEL-FREQUENCY> |
              Configures the channel frequency. A list of unique channels in the 2.4, 4.9, 5
                and 6 GHz band can be collectively or individually enabled for customized channel
                scans and RSSI reporting.
                  - <CHANNEL-FREQUENCY> –
                    Specify a single or multiple, ‘comma-separated‘ channel frequencies.
              | width [20MHz| 40MHz-Both| 40MHz-Lower| 40MHz-Upper| 80MHz] |
              Configures the channel width. When custom channels are selected for RSSI scans,
                each selected channel can have its own width defined. Numerous channels have their
                width fixed at 20MHz, 802.11a radios support 20 and 40 MHz channel widths.
                  - 20MHz – Sets the channel width
                    as 20 Mhz
                  - 40Mhz-Both – Sets the channel
                    width as 40Mhz-Both
                  - 40Mhz-Lowe – Sets the channel
                    width as 40Mhz-Lower
                  - 40Mhz-Upper – Sets the channel
                    width as 40Mhz-Upper
                  - 80Mhz – Sets the channel width
                    as 80Mhz
              | scan-weight <SCAN-WEIGHT> |
              Configures the scan-weight (scanning duration) for each of the selected
                channels. Each selected channel can have its weight prioritized in respect to the
                amount of time a scan is permitted within the defined RSSI scan interval.
                  - <SCAN-WEIGHT> – Specify
                    the scan weightage given to each selected channel.
