authentication
      Specifies an authentication scheme
         used for an OSPF area used with the OSPF dynamic route
            - Access Points — AP410i/e, AP460i/e,
               AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432,
               AP8533
      Syntax
         authentication [message-digest|simple-password]
      Parameters
                     | message-digest |
                     Configures a message-digest (MD-5) authentication scheme |
                     | simple-password |
                     Configures a simple password authentication scheme |
      Usage Guidelines
         OSPF packet authentication enables routers to use predefined passwords and participate
            within a routing domain. The two authentication modes are:
               - MD-5 – MD-5 authentication is a
                  cryptographic authentication mode, where every router has a key (password) and
                  key-id configured on it. This key and key-id together form the message digest that
                  is appended to the OSPF packet.
               - Simple Password – Simple password
                  authentication allows a password (key) to be configured per area. Routers in the
                  same area and participating in the routing domain have to be configured with the
                  same key.
         nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#authentication simple-password
         nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#show context
  area 0.0.0.1
   area-type stub default-cost 1
