maximum-prefix (bgp-neighbor-config)
      Configures the maximum number of prefixes that can be received from a
        BGP neighbor. This option is disabled by default.
        - Service Platforms — NX9500, NX9600
    Syntax
      maximum-prefix <1-4294967295> {(<1-100>|restart <1-65535>|warning-only)}
    Parameters
              | maximum-prefix <1-4294967295> |
                received from a BGP neighbor
                  - <1-4294967295> – Specify a value for 1 - 4294967295.
                      - <1-100> – Optional. Sets the threshold limit for generating a log
                        message. This value represents a percentage of the maximum-prefix configured
                        in the preceding step. When this value is reached, a log entry is generated.
                        For example if the maximum-prefix is set to 100 and threshold limit is set
                        to 65, then after receiving 65 prefixes, a log entry is generated. This
                      - restart <1-65535> – Optional. Restarts BGP peer connection once the
                        maximum-prefix limit specified is exceeded. For example, If the value
                        specified is 10, then after receiving 10 prefixes from the neighbor, the
                        system restarts the connection with that neighbor. Specify a value from 1 -
                        65535. This option is disabled by default.
                      - warning-only – Configure to enable. When the maximum-prefix limit is
                        exceeded, the connection is restarted. However, when this option is enabled,
                        the connection is not restarted and an event is generated instead. This
      nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#maximum-prefix 400 50 warning-only
      nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show con
  bgp neighbor 192.168.13.99
   advertisement-interval 100
   allowas-in 10
   attribute-unchanged as-path
   capability orf prefix-list both
   default-originate
   description neighbor "This neighbor is an external AS neighbor"
   disable-connected-check
   dont-capability-negotiate
   ebgp-multihop 20
   enforce-multihop
   local-as 20 no-prepend
