smart-sensor
Displays smart-sensor trigger and scan status. The Smart-sensor feature auto-provisions tri-radio APs as sensors. Smart-sensor uses an algorithmic function to identify tri-radio APs best suited to be provisioned as sensors. Use this command to view the calibration and scan status.
Syntax
show smart-sensor [scan-status|automatic-trigger-status]
Parameters
smart-sensor Displays Smart-sensor related statistics, such as auto-trigger status
scan-status Displays Smart-sensor scan status
automatic-trigger-status Displays automatic-trigger status. After the Smart-sensor calibration is triggered, use this option to view if the calibration is in progress or has completed.
ap8533-06F89E#show smart-sensor automatic-trigger-status
RF-DOMAIN           STATE
smart         calibration-completed
ap8533-06F89E#
ap8533-06F89E#show smart-sensor scan-status
RADIO-MAC              SCAN-STATE
74-67-F7-08-D7-A0        DONE
74-67-F7-6D-43-90        DONE
Total number of radios displayed: 2
ap8533-06F89E#
