interface-config-radio-instance
Captures and redirects packets to an IP address running a packet capture/analysis tool
sniffer-redirect [omnipeek|tzsp] <IP> channel [1|10|100|100w --------]
{snap <1-65535> (append descriptor)}
      sniffer-redirect [omnipeek|tzsp] <IP> channel [1|10|100|100w ---------]
| sniffer-redirect | Captures and redirects packets to an IP address running a packet capture/analysis tool |
| omnipeek | Encapsulates captured packets in proprietary header (used with OmniPeek and plug-in) |
| tzsp | Encapsulates captured packets in TZSP (used with WireShark and other tools) |
| <IP> | Specify the IP address of the device running the capture/analysis tool (the host to which captured off channel scan packets are redirected) |
| [1|10|100|100w ----------] | Specify the
                        channel to capture packets
| snap <1-65535> | Optional. Allows
                        truncating of large captured frames at a specified length (in bytes). This
                        option is useful when capturing traffic with large frames. Use this option
                        when only headers are needed for analysis, since it reduces the bandwidth
                        needed for sniffing, and (for typical values) eliminates any fragmentation
                        of the outer packet.
| append descriptor | Optional – Enables appending of the radio's receive descriptor to the captured packet |
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#sniffer-redirect omnipeek 172.16.10.1 channel 1 nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 rf-mode sensor placement outdoor mesh client rts-threshold 100 off-channel-scan channel-list 2.4GHz 1 guard-interval long aggregation ampdu tx-only rifs tx-only sniffer-redirect omnipeek 172.16.10.1 channel 1 aeroscout forward ekahau forward ip 172.16.10.1 port 3 non-unicast tx-rate bss 1 dynamic-all non-unicast tx-rate bss 2 highest-basic non-unicast tx-rate bss 3 highest-basic non-unicast tx-rate bss 4 highest-basic non-unicast tx-rate bss 5 highest-basic non-unicast tx-rate bss 6 highest-basic --More-- nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
| no (radio-interface-config-command) | Disables packet capture and redirection |
