DDNS (Dynamic DNS) parameters. Dynamic DNS provides a way to access an individual device in a DHCP serviced network using a static device name.
Depending on the DHCP server‘s configuration, the IP address of a device changes periodically. To ensure continuous accessibility to a device (having a dynamic IP address), the device‘s current IP address is published to a DDNS server that resolves the static device name (used to access the device) with a changing IP address.
The DDNS server must be accessible from outside the network and must be configured as an address resolver.
ddns [domainname|multiple-user-class|server|ttl]
ddns domainname <DDNS-DOMAIN-NAME>
ddns multiple-user-class
ddns server [<IP>|<HOST-ALIAS-NAME>] {<IP1>|<HOST-ALIAS-NAME1>}
         ddns ttl <1-864000>
                         domainname <DDNS-DOMAIN-NAME>  |
                         Sets the domain name used for DNS updates The controller uses DNS to convert human readable host names into IP addresses. Host names are not case sensitive and can contain alphabetic or numeric letters or a hyphen. A FQDN (fully qualified domain name) consists of a host name plus a domain name. For example, computername.domain.com.  |
                         multiple-user-class  |
                         Enables the multiple user class options with this DDNS domain  |
                         server  |
                         Configures the DDNS server used by this DHCP profile  |
                         [<IP>|<HOST-ALIAS- NAME>]  |
                         Configures the primary DDNS server. This is the default server. Use one of the following options to specify the primary DDNS server:
 Note: A
                           network host alias maps a name to a single network
                           host. For example, ‘alias host $HOST 1.1.1.100‘. In
                           this example the host alias is ‘$HOST‘ and it maps to
                           a single host ‘1.1.1.100‘. For more information, see
                              alias.
                         {<IP1>|<HOST-ALIAS -NAME1>}  |
                         Optional. Configures the secondary DDNS server. If the primary server is not reachable, this server is used. Use one of the following options to identify the secondary DDNS server:
ddns ttl <1-864000>
                         ttl <1-864000>  |
                         Configures the TTL (Time To Live) value for DDNS updates
nx9500-6C8809(config-dhcp-policy-test-pool-testPool)#ddns domainname WID
nx9500-6C8809(config-dhcp-policy-test-pool-testPool)#ddns multiple-user-class
nx9500-6C8809(config-dhcp-policy-test-pool-testPool)#ddns server 192.168.13.9
nx9500-6C8809(config-dhcp-policy-test-pool-testPool)#show context dhcp-pool testPool address 192.168.13.4 class dhcpclass1 ddns server 192.168.13.9 ddns domainname WID ddns multiple-user-class bootfile test.txt nx9500-6C8809(config-dhcp-policy-test-pool-testPool)#
| no |
                         Resets or disables a DHCP pool's DDNS settings  |
