Removes the DHCP options match criteria configurations
no [dhcp <1-16>|dhcp-match-message-type]
                         dhcp <1-16>  |
                         Removes the DHCP option match criteria rule identified by the <1-16> keyword
                         dhcp-match-message-type  |
                         Removes the DHCP message type to match  |
The following example shows the client identity ‘test‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-client-identity-test)#show context client-identity test dhcp 2 message-type discover option 2 exact hexstring 012456c22c44 dhcp 1 message-type request option 60 exact ascii MSFT5.0 dhcp-match-message-type all nx9500-6C8809(config-client-identity-test)#
The following example shows the client identity ‘test‘ settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-client-identity-test)#no dhcp 2
         nx9500-6C8809(config-client-identity-test)#no dhcp-match-message-type
         nx9500-6C8809(config-client-identity-test)#show context client-identity test dhcp 1 message-type request option 60 exact ascii MSFT5.0 nx9500-6C8809(config-client-identity-test)#
