An EX3500 time range list consists of a set of periodic and absolute time range rules. Periodic time ranges recur periodically at specified time periods, such as daily, weekly, weekends, weekdays, and on specific week days, for example on every successive Mondays. Absolute time ranges are not periodic and do not recur. They consist of a range of days during a particular time period (the starting and ending days and time are fixed).
The EX3500 series switch is a Gigabit Ethernet layer 2 switch with either 24 or 48 10/100/1000-BASE-T ports, and four Small Form-factor Pluggable (SEP) transceiver slots for fiber connectivity. The EX3500 series switch can adopt to a NOC controller and be managed by it. The EX3500 time range values configured here are used in EX3500 MAC ACL firewall rules that filter an EX3500‘s incoming and outgoing traffic.
For more information on creating EX3500 rules, see ex3500 (mac-acl-config-commands).
ex3500 time-range <TIME-RANGE-NAME>
| ex3500 time-range <TIME-RANGE-NAME> | Configures EX3500 time range list and enters its
                configuration mode
nx9500-6C8809(config)#ex3500 time-range EX3500_TimeRange_02 nx9500-6C8809(config-ex3500-time-range-EX3500_TimeRange_02)#? nx9500-6C8809 Time Range Configuration commands: absolute Absolute time and date no Negate a command or set its defaults periodic Periodic time and date clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-ex3500-time-range-EX3500_TimeRange_02)#
| no | Removes this EX3500 time range list |
