When enabled, the AP mandates the RU allocation for multiple clients for both downlink (dl) and uplink (ul) OFDMA. A series of trigger frames are exchanged to allow multi-user transmission in the both directions - downlink and uplink.
Use this command to enable support for OFDMA in both or one direction. OFDMA support is disabled by default. Specify a guard-interval to avoid overlapping of OFDMA symbols.
11axOFDMA [both|dl|ul]
| 11axOFDMA [both|dl|ul] | Configures support for 802.11ax OFDMA in the following
                                    directions:
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#11axOFDMA both
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#show context interface radio1 11axSupport 11axOFDMA both 11axBSScolor 20 ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#
| no (radio-interface-config-command) | Disables OFDMA support on the selected radio |
