Selects an interface to configure
A profile‘s interface configuration can be defined to support separate physical Ethernet configurations both unique and specific to device type. Ports vary depending on the platform, but controller or service platform models do have some of the same physical interfaces.
A controller or service platform requires its virtual interface be configured for layer 3 (IP) access or layer 3 service on a VLAN. A virtual interface defines which IP address is associated with each VLAN ID the controller or service platform is connected to.
If the profile is configured to support an access point radio, an additional radio interface is available, unique to the access point‘s radio configuration.
interface [<INTERFACE-NAME>|fe <1-4>|ge <1-24>|me1|port-channel <1-4>|pppoe1| radio [1|2|3]|serial <1-4>|t1e1 <1-4>|up <1-2>|vlan <1-4094>|wwan1|xge <1-4>]
interface [<INTERFACE-NAME>|bluetooth <1-1>|fe <1-4>|ge <1-8>|me1|port-channel <1-4>| pppoe1|radio [1|2|3]|up1|vlan <1-4094>|wwan1|xge <1-4>]
interface [<INTERFACE-NAME>|bluetooth <1-1>|fe <1-4>|ge <1-8>|me1|port-channel <1-4>| radio [1|2|3]|serial <1-4>|t1e1 <1-4>|up <1-2>|vlan <1-4094>|wwan1|xge <1-4>]
| <INTERFACE-NAME> | Enters the configuration mode of the interface identified by the <INTERFACE-NAME> keyword |
| bluetooth <1-1> | Selects the
                        Bluetooth radio interface
 This interface is applicable only for the AP8432 and AP8533 model access points.  |
| fe <1-4> | Selects a
                        FastEthernet interface
| ge <1-24> | Selects a
                        GigabitEthernet interface
| me1 | Selects a management interface |
| port-channel <1-4> | Selects the port
                        channel interface
| pppoe1 | Selects the PPP over Ethernet interface to configure |
| radio [1|2|3] | Selects a radio
                           interface
 The radio interface is not available on wireless controllers or service platforms.  |
| up1 | Selects the uplink GigabitEthernet interface |
| vlan <1-4094> | Selects a VLAN
                           interface
| xge <1-4> | Selects a
                        TenGigabitEthernet interface
GE ports are available on WiNG controllers and access points, such as the NX9500 service paltform and AP510. GE ports are RJ-45 supporting 10/100/1000Mbps.
ME ports are out-of-band management ports used to manage the controller via CLI or Web UI, even when the other ports on the controller are unreachable.
An UP port is used to connect to the backbone network. An UP port supports either RJ-45 or fiber. The UP port is the preferred means to connect to the backbone as it has a non-blocking 1gbps connection unlike the GE ports.
For a NX7500 model service platform, there are options for either a 2 port or 4 port network management card. Either card can be managed using WiNG. If the 4 port card is used, ports ge7-ge10 are available. If the 2 port card is used, ports xge1-xge2 are available.To access an AP's interface configuration mode, in the AP's profile or device context, issue the following commands:
ap505-13403B(config-device-94-9B-2C-13-40-38)#interface ? WORD Interface name bluetooth Bluetooth interface fe Select a FastEthernet interface ge Select a GigabitEthernet interface me1 Select the management interface port-channel Select a port channel interface radio Select a radio up1 Select the Uplink GigabitEthernet interface vlan Select a vlan interface (switched virtual interface) xge Select a TenGigabitEthernet interface ap505-13403B(config-device-94-9B-2C-13-40-38)#interface
ap505-13403B(config-device-94-9B-2C-13-40-38-if-bluetooth1)#? Bluetooth Radio Mode commands: beacon Configure low-energy beacon operation parameters description Configure a description for this bluetooth radio eddystone Configure eddystone beacon payload parameters ibeacon Configure iBeacon beacon payload parameters mode Set the bluetooth opreation mode no Negate a command or set its defaults shutdown Shutdown the selected bluetooth radio interface clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal ap505-13403B(config-device-94-9B-2C-13-40-38-if-bluetooth1)#
nx9500-6C8809(config-profile-test510)#interface radio 1
nx9500-6C8809(config-profile-test510-if-radio1)#?
  adaptivity                  Adaptivity
  aeroscout                   Aeroscout Multicast MAC/Enable
  aggregation                 Configure 802.11n aggregation related parameters
  airtime-fairness            Enable fair access to medium for clients based
                              on their usage of airtime
  antenna-diversity           Transmit antenna diversity for non-11n transmit
                              rates
  antenna-downtilt            Enable ADEPT antenna mode
  antenna-elevation           Specifies the antenna elevation gain
  antenna-gain                Specifies the antenna gain of this radio
  antenna-mode                Configure the antenna mode (number of transmit
                              and receive antennas) on the radio
  assoc-response              Configure transmission parameters for
                              Association Response frames
  association-list            Configure the association list for the radio
  beacon                      Configure beacon parameters
  bridge                      Bridge rf-mode related configuration
  channel                     Configure the channel of operation for this
                              radio
  data-rates                  Specify the 802.11 rates to be supported on this
                              radio
--More--
| no | Removes the selected interface |
