payload-size
    (iot-device-type-imagotag-policy)
    Configures the maximum size of the
      payload in packets exchanged between ESL communicator and tags
        - Access Points — AP-8432
        - Wireless Controllers — RFS 4000
        - Service Platforms — NX 5500, NX 75XX, NX 95XX, NX 96XX, VX 9000
    Syntax
      payload-size <1-32>
    Parameters
      payload-size <1-32>
              | payload-size <1-32> |
              Configures the packet‘s payload size
                  - <1-32> – Specify the value from 1 - 32 bytes. The
                    default setting is 32 bytes.
                 Note: SES-Imagotags recommends NOT to change the default
                  setting.
      nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#payload-size 25
      nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#show context
 iot-device-type-imagotag-policy ImagoTagPolicy
  enable
  output-power Level-B
  payload-size 25
  fcc-enable
  channel 9
