Enables interference recovery from neighboring radios and other sources of WiFi and non-WiFi interference when excess noise and interference is detected within the Smart RF supported radio coverage area. Smart RF provides mitigation from interference sources by monitoring the noise levels and other RF parameters on an access point radio's current channel. When a noise threshold is exceeded, Smart RF can select an alternative channel with less interference. To avoid channel flapping, a hold timer is defined which disables interference avoidance for a specific period of time upon detection. Interference recovery is enabled by default.
The interference-recovery parameters can be modified only if the sensitivity level is set to ‘custom‘. By default 'sensitivity' is set to 'medium'. However, if you change the interference-recovery settings, without changing the sensitivity level, the sensitivity setting automatically changes to 'custom'. For more information, see sensitivity.interference-recovery {channel-blacklist-timeoutchannel-hold-time|channel-switch-delta|client-threshold|interference|neighbor-offset|noise|noise-factor}
         interference-recovery channel-blacklist-timeout <10-3600>
interference-recovery {channel-switch-delta [2.4GHz|5GHZ|6GHZ] <5-35>}
         interference-recovery {channel-hold-time <0-86400>|client-threshold <1-255>|interference|neighbor-offset <3-10>|noise|noise-factor <1.0-3.0>}
| channel-blacklist-timeout <10-3600> | Optional. Modifies the time, in seconds, for which a channel
                        remains blacklisted.  When a Smart RF monitored radio enters a 'continuous
                           beacon stuck' state (i.e. the radio is stuck on a channel and stops
                           beaconing), Smart RF blacklists the channel. By default, the channel
                           remains blacklisted for 15 minutes (900 seconds). You can use
                           'channel-blacklist-timeout' parameter to change the default value.
         | channel-switch-delta | Optional. Configures a threshold value for the difference between interference levels on the current channel and the prospective channel needed to trigger a channel change. If the difference in noise levels on the current channel and the prospective channel is below the configured threshold, the channel is not changed. |
| [2.4GHz|5GHz|6GHZ] | Selects the band
| <5-35> | Specifies the threshold value for the difference between the current and
                        prospective channel interference levels
         | channel-hold-time <0-86400> | Optional. Defines the minimum time between two channel change
                           recoveries
| client-threshold <1-255> | Optional. Specifies client thresholds needed to
                        avoid channel change. If the specified threshold number of clients are
                        connected to a radio, the radio avoids changing channels even if the Smart
                        RF master determines that a channel change is required.
| interference | Optional. Considers external interference values to perform interference recovery. This feature allows the Smart RF policy to scan for excess interference from supported radio devices. WLANs are susceptible to sources of interference, such as neighboring radios, cordless phones, microwave ovens and Bluetooth devices. When interference for WiFi sources is detected, Smart RF supported devices can change the channel and move to a cleaner channel. This feature is enabled by default. |
| neighbor-offset <3-10> | Optional. Configures a noise factor value, which
                        is taken into consideration when switching channels to avoid interference
                        from neighboring access points. Smart RF enabled access points consider the
                        difference in noise between candidate channels.
| noise | Optional. Considers noise values to perform interference recovery. This feature allows the Smart RF policy to scan for excess noise from WiFi devices. When detected, Smart RF supported devices can change their channel and move to a cleaner channel. This feature is enabled by default. |
| noise-factor <1.0-3.0> | Optional. Configures additional noise factor (the
                        level of network interference detected) for non WiFi interference
nx9500-6C8809(config-smart-rf-policy-test6)#interference-recovery channel-blacklist-timeout 20
nx9500-6C8809(config-smart-rf-policy-test6)#interference-recovery channel-switch-delta 2.4GHz 10
nx9500-6C8809(config-smart-rf-policy-test6)#show context smart-rf-policy test6 sensitivity custom area test6 assignable-power 2.4GHz min 8 area test6 assignable-power 2.4GHz max 16 interference-recovery channel-switch-delta 2.4GHz 10 no select-shutdown interference-recovery channel-blacklist-timeout 20 nx9500-6C8809(config-smart-rf-policy-test6)#
| no (smart-rf-policy-config-mode-command) |
                         Disables recovery from excessive noise and interference  |
