Enables support for 802.11 WEP shared key authentication
When enabled, devices, using this profile, use a WEP key to access the network. The controller or service platform use the key algorithm to convert an ASCII string to the same hexadecimal number. Clients without the recommended adapters need to use WEP keys manually configured as hexadecimal numbers. This option is disabled by default.
None
nx9500-6C8809(config-profile-TestNX5500)#wep-shared-key-auth nx9500-6C8809(config-profile-TestNX5500)#show context profile nx5500 TestNX5500 bridge vlan 1 bridging-mode isolated-tunnel ip igmp snooping ip igmp snooping querier wep-shared-key-auth autoinstall configuration autoinstall firmware crypto ikev1 policy ikev1-default isakmp-proposal default encryption aes-256 group 2 hash sha crypto ikev2 policy ikev2-default isakmp-proposal default encryption aes-256 group 2 hash sha crypto ipsec transform-set default esp-aes-256 esp-sha-hmac crypto ikev1 remote-vpn crypto ikev2 remote-vpn crypto auto-ipsec-secure interface me1 interface ge1 ip dhcp trust qos trust dscp qos trust 802.1p interface ge2 ip dhcp trust --More-- nx9500-6C8809(config-profile-TestNX5500)#
| no | Disables support for 802.11 WEP shared key authentication |
