Configures the application category type for this custom (user-defined) purview-application definition
This parameter is applicable only for the 802.11ax APs. Define the purview-app-category type of this custom application definition. Apply this custom application definition in the purview-application-group and purview-application-policy contexts.
This parameter is not applicable on the legacy APs (AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8432, AP8533). Use theapp-category parameter instead.purview-app-category <PURVIEW-APP-CATEGORY-NAME>
| purview-app-category <PURVIEW-APP-CATEGORY-NAME> | Select the category best suited for this application definition.
The ExtremeAnalytics for ExtremeCloud IQ - Site Engine, formerly known as Purview™,
supports 36 application categories with 2457 applications. Note: Refer to Examples below for the app-categories supported by
the Purview™ engine.
The default setting is custom. Use this option to categorize your internal custom applications, so that they do not appear as unknown traffic. |
nx9500-6C8809(config-application-Custom)#purview-app-category ads biz certs cloud cloudcpu corp custom db education finance games health location mail news other p2p proto realtimecomms restrictcontent search shopping social sports storage streaming travel unknown updates vpn webapp webcontent webfile webmeet nx9500-6C8809(config-application-Custom)#
The following example displays the canned (built-in, system-provided apps) starting with 'h':
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#application h [TAB] hashforcash hashunited hoopla nx9500-6C8809(config-purview-app-group-PurvAppGrp)#
The following example, creates application definition hulu and assigns it to the app-category streaming.
nx9500-6C8809(config)#application hulu nx9500-6C8809(config-application-hulu)# nx9500-6C8809(config-application-hulu)#purview-app-category streaming nx9500-6C8809(config-application-hulu)#show context application hulu purview-app-category streaming nx9500-6C8809(config-application-hulu)#
The following example shows hulu application definition added to the list of available applications:
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#application h [TAB] hashforcash hashunited hoopla hulu nx9500-6C8809(config-purview-app-group-PurvAppGrp)#
| no | Resets application category to default (custom) |
