Adds device adoption rules to the Auto Provisioning Policy
adopt [anyap|ap41ap460|ap505|ap510|ap560|nx5500|nx75xx|nx9000|vx9000|nx9600]
adopt [anyap|ap41ap460|ap505|ap510|ap560|nx5500|nx75xx|nx9000|vx9000|nx9600] precedence <1-10000> [profile|rf-domain]
adopt [anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx9000|vx9000|nx9600] precedence <1-10000> [profile <DEVICE-PROFILE-NAME>|rf-domain <RF-DOMAIN-NAME>] [any|area|cdp-match|dhcp-option|floor| fqdn|ip|ipv6|lldp-match|mac|model-number|rf-domain|serial-number|vlan]
adopt [anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx9000|vx9000|nx9600] precedence <1-10000> [profile <DEVICE-PROFILE-NAME>|rf-domain <RF-DOMAIN-NAME>] any
[profile <DEVICE-PROFILE-NAME>|rf-domain <RF-DOMAIN-NAME>] [area <AREA-NAME>|
cdp-match <LOCATION-SUBSTRING>|dhcp-option <DHCP-OPTION>|floor <FLOOR-NAME>|fqdn <FQDN>|
ip [<START-IP> <END-IP>|<IP/MASK>]|ipv6 [<START-IP> <END-IP>|<IP/MASK>]|lldp-match <LLDP-STRING>|
mac <START-MAC> {<END-MAC>}|model-number <MODEL-NUMBER>|serial-number <SERIAL-NUMBER>|
rf-domain <RF-DOMAIN-NAME>|vlan <VLAN-ID>]
adopt |
Adds an adopt device rule. The rule applies to the selected device
types. Specify the device type and assign a precedence to the rule. The different device types are: AP410, AP460. AP505, AP510, AP560, NX5500, NX7500, NX9500, NX9600, and VX9000. Note: Use the ‘anyap‘ option to
auto provision any AP regardless of its model type.
precedence <1-10000> |
Sets the rule precedence from 1 - 10000. A rule with a lower value has a higher precedence. |
profile <DEVICE-PROFILE- NAME> |
Sets the device profile for this provisioning policy. The selected device profile must be appropriate for the device being provisioned. For example, use an AP505 device profile for an AP505. Using an inappropriate device profile can result in unpredictable results. Provide a device profile name. Provide a device profile name (should be existing and configured). Or a template with appropriate substitution tokens, such as 'campus-$MODEL[1:6]', 'FQDN[1:4]-indoor'. Refer to Usage Guidelines: Built-in Tokens & Alias for the different types of built in tokens available in the system. |
rf-domain <RF-DOMAIN-NAME> |
Sets the RF Domain for this auto provisioning policy. The provisioning policy is only applicable to devices that try to become a part of the specified RF Domain. Provide the full RF Domain name OR use a string alias to identify the RF Domain. Provide the full RF Domain name or an alias (should be existing and configured). Or a template with appropriate substitution tokens, such as '$CDP[1:7]', '$DNS-SUFFIX[1:5]'. Use the built-in string alias or a user-defined string alias. String aliases allow you to configure APs in the same RF Domain as the adopting controller. A string alias maps a name to an arbitrary string value, for example, ‘alias string $DOMAIN test.example_company.com‘. In this example, the string-alias $DOMAIN is mapped to the string: test.example_company.com. |
any |
Indicates any device. Any device seeking adoption is adopted. |
[area <AREA-NAME>|cdp-match <LOCATION-SUBSTRING>|dhcp-option <DHCP-OPTION>|floor <FLOOR-NAME>|
fqdn <FQDN>|ip [<START-IP> <END-IP>|<IP/MASK>]|ipv6 [<START-IP> <END-IP>|<IP/MASK>]|
lldp-match <LLDP-STRING>|mac <START-MAC> {<END-MAC>}|model-number <MODEL-NUMBER>|
serial-number <SERIAL-NUMBER>|rf-domain <RF-DOMAIN-NAME>|vlan <VLAN-ID>]
adopt |
Sets the rule precedence. A rule with a lower value has a higher precedence. |
Sets the device profile for this provisioning policy. The selected device profile must be appropriate for the device being provisioned. For example, use an AP505 device profile for an AP505 . Using an inappropriate device profile can result in unpredictable results. Provide a device profile name. Provide a device profile name (should be existing and configured). Or a template with appropriate substitution tokens, such as 'campus-$MODEL[1:6]', 'FQDN[1:4]-indoor'. |
Sets the RF Domain for this auto provisioning policy. The provisioning policy is only applicable to devices that try to become a part of the specified RF Domain. Provide the full RF Domain name OR use a string alias to identify the RF Domain. Provide the full RF Domain name or an alias (should be existing and configured). Or a template with appropriate substitution tokens, such as '$CDP[1:7]', '$DNS-SUFFIX[1:5]'. Note: Use
| area <AREA-NAME> | Matches the area of deployment. This option is
not applicable to the ‘rf-domain‘ parameter.
| cdp-match <LOCATION-SUBSTRING> | Matches a substring in a list of CDP snoop
strings (case insensitive). For example, if an access point snooped 3
devices: controller1.example.com, controller2.example.com, and
controller3.example.com, 'controller1', ‘example‘, 'example.com', are
examples of the substrings that will match.
| dhcp-option <DHCP-OPTION> | Matches the value found in DHCP vendor option 191
(case insensitive). DHCP vendor option 191 can be setup to communicate
various configuration parameters to an AP. The value of the option in a
string in the form of tag=value separated by a semicolon, for example
'tag1=value1;tag2=value2;tag3=value3'. The access point includes the value
of tag 'rf-domain', if present.
| floor <FLOOR-NAME> | Matches the floor name. This option is not
fqdn <FQDN> |
Matches a substring to the FQDN (Fully Qualified Domain Name) of a device (case insensitive) FQDN is a domain name that specifies its exact location in the DNS hierarchy. It specifies all domain levels, including its top-level domain and the root domain. This parameter allows a device to adopt based on its FQDN value.
ip [<START-IP> <END-IP>| <IP/MASK>] |
Adopts a device if its IP address matches the specified IPv4 address or is within the specified IP address range. Or if the device is a part of the specified subnet.
| ipv6 [<START-IP> <END-IP>| <IP/MASK>] |
Adopts a device if its IP address matches the specified IPv6 address or is within the specified IP address range. Or if the device is a part of the specified subnet.
lldp-match <LLDP-STRING> |
Matches a substring in a list of LLDP (Link Layer Discovery Protocol) snoop strings (case insensitive). For example, if an Access Point snooped 3 devices: controller1.example.com, controller2.example.com and controller3.example.com,'controller1', 'example', 'example.com', are substrings match. LLDP is a vendor neutral link layer protocol that advertises a network device‘s identity, capabilities, and neighbors on a local area network.
mac <START-MAC> {<END-MAC>} |
Adopts a device if its MAC address matches the specified MAC address or is within the specified MAC address range <START-MAC> – Specify the first MAC address in the range. Provide this MAC address if you want to match for a single device.
model-number <MODEL-NUMBER> |
Adopts a device if its model number matches <MODEL-NUMBER>
serial-number <SERIAL-NUMBER> |
Adopts a device if its serial number matches <SERIAL-NUMBER>
vlan <VLAN-ID> |
Adopts a device if its VLAN matches <VLAN-ID>
$FQDN - references FQDN of adopting device
$CDP - references CDP Device Id of the wired switch to which adopting device is connected
$LLDP - references LLDP System Name of wired switch to which adopting device is connected
$DHCP - references DHCP Option Value received by the adopting device
$SN - references SERIAL NUMBER of adopting device
$MODEL - references MODEL NUMBER of adopting device
$DNS-SUFFIX - references FQDN excluding the hostname of the adopting device
$CDP-SUFFIX - references CDP excluding the hostname of the adopting device
$LLDP-SUFFIX - references LLDP excluding the hostname of the adopting device
$AUTO-RF-DOMAIN - rf-domain of adopting device
nx9500-6C8809(config-auto-provisioning-policy-test)#adopt ap8432 precedence 5 profile default-ap8432 rf-domain TechPubs vlan 1
nx9500-6C8809(config-auto-provisioning-policy-test)#show context auto-provisioning-policy test adopt ap8432 precedence 5 profile default-ap8432 rf-domain TechPubs vlan 1 nx9500-6C8809(config-auto-provisioning-policy-test)#
nx9500-6C8809(config-auto-provisioning-policy-test)#show wireless ap configured --------------------------------------------------------------------------------------- IDX NAME MAC PROFILE RF-DOMAIN ADOPTED-BY --------------------------------------------------------------------------------------- 1 ap8432-711728 B4-C7-99-71-17-28 default-ap8432 default 00-23-68-22-9D-58 --------------------------------------------------------------------------------------- nx9500-6C8809(config-auto-provisioning-policy-test)#
| no |
Removes an adopt device rule from this Auto Provisioning Policy |
