Enables export of startup.log file after every boot
export startup-log [max-retries|retry-interval|url]
export startup-log [max-retries <2-65535>|retry-interval <30-86400>|url <URL>]
| export startup-log | Enables export of the startup.log file after every boot. This option is disabled by default. |
| max-retries <2-65535> | Configures the
                        maximum number of retries in case the export process fails
| retry-interval <30-86400> | Configures the
                        interval between two consecutive retries
| url <URL> | Configures the
                        destination URL in the following format: tftp://<hostname|IP>[:port]/path/file ftp://<user>:<passwd>@<hostname|IP>[:port]/path/file sftp://<user>@<hostname|IP>[:port]>/path/file  |
nx9500-6C8809(config-profile-test-nx5500)#export startup-log max-retries 10 retry-interval 30 url ftp://anonymous:anonymous@192.168.13.10/log/startup.log nx9500-6C8809(config-profile-test-nx5500)#show context profile nx5500 test-nx5500 no autoinstall configuration no autoinstall firmware crypto ikev1 policy ikev1-default ....................................................... interface ge5 interface ge6 interface pppoe1 use firewall-policy default export startup-log max-retries 10 retry-interval 30 url ftp://anonymous:anonymous@192.168.13.10/log/startup.log enforce-version adoption major enforce-version cluster full service pm sys-restart --More-- nx9500-6C8809(config-profile-test-nx5500)#
| no | Disables export of startup.log file |
