Assigns a default role to a wireless client that fails to match any of the user-defined roles
When a wireless client accesses a network, the client‘s details, retrieved from the LDAP server, are matched against all user-defined roles within the role policy. If the client fails to match any of these user-defined role filters, the client is assigned the default role. The action taken (permit or deny access) is determined by the IP and/or MAC ACL associated with the default role.
default-role use [ip-access-list|ipv6-access-list|mac-access-list]
default-role use [ip-access-list|ipv6-access-list|mac-access-list] [in|out] <IP/IPv6/MAC-ACCESS-LIST-NAME> precedence <1-100>
                         default-role use  |
                         Enables default role configuration. This role is applied to a wireless client not matching any of the user-defined roles.
| [ip-access-list| ipv6-access-list| mac-access-list] [in|out] <IP/IPv6/MAC-ACCESS-LIST-NAME> |
                         Associates an IP access list, IPv6 access list, or a MAC access list with this default role
 IP and MAC ACLs act as firewalls by blocking and/or permitting data traffic in both directions (inbound and outbound) within a managed network. IP ACLs use IP addresses for matching operations. Whereas, MAC ACLs use MAC addresses for matching operations, In case of a match (i.e. if a packet is received from or is destined for a specified IP or MAC address), an action is taken. This action is a typical allow, deny or mark designation to controller packet traffic. For more information on ACLs, see Access-List Policy.
 The ACL applied determines the action applied to a client assigned the default role.  |
                         precedence <1-100>  |
                     The following keyword is common to the all of the
                        above parameters:
 ACLs are applied in increasing order of their precedence. Rules with lower precedence are given priority.  |
nx9500-6C8809(config-role-policy-test)#default-role use ip-access-list in test precedence 1
nx9500-6C8809(config-role-policy-test)#show context role-policy test default-role use ip-access-list in test precedence 1 nx9500-6C8809(config-role-policy-test)#
| no (role-policy-config-mode-command) |
                         Removes or resets the default role configuration  |
