Configures a Network Access Identifier (NAI) realm name and enters its configuration mode
The NAI is the user identity submitted by the hotspot requesting client during authentication. The standard syntax is user@realm. NAI is frequently used when roaming, to identify the user and assist in routing an authentication request to the user's authentication server. The realm name is often the domain name of the service provider.
You can configure a list of NAI realm names of service providers operating within a specific hotpsot zone. This NAI realm name list is presented in ANQP response to a NAI realm and NAI home realm query.
nai-realm <NAI-REALM-NAME>
                         nai-realm <NAI-REALM-NAME>  |
                         Configures the NAI realm name for this passpoint policy
nx9500-6C8809(config-passpoint-policy-test)#nai-realm example nx9500-6C8809(config-passpoint-policy-test-nai-realm-example)#? Passpoint NAI Realm Mode commands: eap-method Set an eap method no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-passpoint-policy-test-nai-realm-example)#
nx9500-6C8809(config-passpoint-policy-test)#show context passpoint-policy test access-network-type chargeable-public connection-capability ip-protocol 2 port 10 closed nai-realm example 3gpp mcc 505 mnc 14 nx9500-6C8809(config-passpoint-policy-test)#
The following table summarizes NAI realm configuration mode commands.
| Command | Description |
| eap-method | Specifies the EAP authentication mechanisms supported by each of the service providers associated with this passpoint policy. |
| no |
                         Removes the NAI realm name configured for this passpoint policy  |
