Enables eBGP Multihop on this BGP neighbor. When enabled, allows neighbor connection to be established between two eBGP neighbors that are not directly connected to each other. Use this command to configure the maximum number of hops possible between two such eBGP neighbors. This option is disabled by default.
Wireless Controllers — RFS 4000
Service Platforms — NX 95XX, NX 96XX
ebgp-multihop <1-255>
| ebgp-multihop <1-255> | Configures the maximum number of hops that can be
between eBGP neighbors not directly connected to each other.
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#ebgp-multihop 20
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context bgp neighbor 192.168.13.99 advertisement-interval 100 allowas-in 10 attribute-unchanged as-path capability orf prefix-list both default-originate description neighbor "This neighbor is an external AS neighbor" disable-connected-check dont-capability-negotiate ebgp-multihop 20 nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#
| no (bgp-neighbor-config) | Disables eBGP Multihop on this BGP neighbor |
