use (bgp-neighbor-config)
    Configures filters for this neighbor.
      These filters are BGP IP ACL, IP prefix list, AS path list, and route map. Based on the
      filters used, updates received from this neighbor are filtered.
        - Service Platforms — NX9500, NX9600
    Syntax
      use [distribute-list <BGP-IP-ACL-NAME>|filter-list <AS-PATH-LIST-NAME>|
prefix-list <IP-PREFIX-LIST-NAME>|route-map <BGP-ROUTE-MAP-NAME>]
    Parameters
              Uses predefined and configured filters with this
                  neighbor
                  - distribute-list <BGP-IP-ACL-NAME> – Uses a BGP IP ACL
                      - <BGP-IP-ACL-NAME> – Specify the BGP IP ACL name.
                  - filter-list <AS-PATH-LIST-NAME> – Uses an AS path list
                      - <AS-PATH-LIST-NAME> – Specify the AS path list name.
                  - prefix-list <IP-PREFIX-LIST-NAME> – Uses a IP prefix list
                      - <IP-PREFIX-LIST-NAME> – Specify the IP prefix list name.
                  - route-map <BGP-ROUTE-MAP-NAME> – Uses a route map
                      - <BGP-ROUTE-MAP-NAME> – Specify the route map name.
      nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp-neighbor-192.168.13.99)#use filter-list FilterList_01 in
      nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp-neighbor-192.168.13.99)#use route-map testBGPRouteMap out
      nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp-neighbor-192.168.13.99)#show context
  bgp neighbor 192.168.13.99
   remote-as 199
   maximum-prefix 9999 80 restart 50
   unsuppress-map test
