rename tlo <TLO-NAME> <NEW-TLO-NAME>
rename tlo <TLO-NAME> <NEW-TLO-NAME> | Renames an existing TLO object
Enter rename and press Tab to list top level objects available for renaming.nx9500-6C8809(config)#rename [TAB] aaa_policy aaa_tacacs_policy address_range_alias aif_policy app_policy application assoc_acl auto_provisioning_policy bgp_as_path_list bgp_community_list bgp_extcommunity_list bgp_ip_access_list bgp_ip_prefix_list bonjour_gw_discovery_policy bonjour_gw_forwarding_policy bonjour_gw_query_forwarding_policy bridging_policy captive_portal centro_policy client_identity client_identity_group content_cache_policy content_filter_policy crypto_cmp_policy database_client_policy database_policy device_categorization dhcp_server_policy dhcpv6_server_policy dns_whitelist dr_route_map encrypted_string_alias event_system_policy ex3500_ext_ip_acl ex3500_management_policy ex3500_qos_class_map_policy ex3500_qos_policy_map ex3500_std_ip_acl ex3500_time_range firewall_policy global_assoc_list guest_management hashed_string_alias host_alias ip_acl ip_snmp_acl --More-- nx9500-6C8809(config)#
The following examples first clones the existing IP access list BROADCAST-MULTICAST-CONTROL, and then renames the cloned IP access list:
nx9500-6C8809(config)#show context include-factory | include ip access-list ip access-list BROADCAST-MULTICAST-CONTROL nx9500-6C8809(config)#
nx9500-6C8809(config)#clone ip_acl BROADCAST-MULTICAST-CONTROL Test_IP_CLONED nx9500-6C8809(config)#commit
nx9500-6C8809(config)#show context include-factory | include ip access-list ip access-list BROADCAST-MULTICAST-CONTROL ip access-list Test_IP_CLONED nx9500-6C8809(config)#
nx9500-6C8809(config)#rename Test_IP_CLONED NEW_IP_CLONED nx9500-6C8809nx9500-6C8809(config)#commit
nx9500-6C8809(config)#show context include-factory | include ip access-list ip access-list BROADCAST-MULTICAST-CONTROL ip access-list NEW_IP_CLONED nx9500-6C8809(config)#
clone | Creates a replica of an existing TLO or device |
