MSM LED Behavior--BlackDiamond 8800 Series Switches
This section describes the MSM behavior during a diagnostic test.
After the I/O modules complete the diagnostic test, or the diagnostic test is terminated, the DIAG and the Status LEDs are reset. During normal operation, the DIAG LED is off and the Status LED blinks green. If you start another diagnostic test, the LED returns to blinking amber.
