| Service | VRF-related command | Additional information |
| Firmware download |
firmware download [ default-config ] ftp | scp | sftp [ use-vrf vrf-name ]... |
Uses TCP IPv4 or IPv6. By default, mgmt-vrf is used: use-vrf is optional. |
| LDAP |
ldap-server host { ip-address | host_name } [ use-vrf vrf-name ] [ port portnum ] [ ldaps ] [ timeout seconds ][ retries num ][ basedn base domain name ] |
Default vrf is mgmt-vrf. use-vrfis optional. |
| Logging server | logging syslog-server { ipv4 | ipv6 address } [ use-vrf vrf-name ] | Uses TCP UDP IPv4 or IPv6. |
| NTP |
ntp server ip-address [ use-vrf vrf-name ] |
Uses NTP UDP IPv4. |
| RADIUS | radius-server host host-name [ use-vrf vrf-name ] | Uses UDP IPv4 or IPv6 |
| sFlow |
[no] sflow collector ipv4/ipv6 address port-number [ use-vrf vrf-name ] [no] sflow source-interface interface-type interface-number |
Uses sFlow UDP IPv4 or IPv6.
In the case of the sflow source-interface command, the VRF of the specified interface is used. Note: Any given interface can belong to only one VRF at any given time.
| SSH Client | ssh { IP_address | hostname } [ -l ] remote user/login name |[vrf vrf-name ] | VRF is optional; default-vrf is used by default. |
| SNMP notification |
snmp-server host ip-address [ use-vrf vrf-name ] snmp-server v3host ip-address [ use-vrf vrf-name ] |
Uses SNMP UDP IPv4 or IPv6.
By default, mgmt-vrf is used to send the SNMP notifications. |
| Support save | copy support { ftp | scp } [ use-vrf vrf-name ] ... |
Uses TCP IPv4 or IPv6. By default, mgmt-vrf is used and a user-defined VRF is optional. |
| TACACS+ | tacacs-server host host-name [ use-vrf vrf-name ] | Uses TCP IPv4 or IPv6 |
| Telnet client | telnetIP_address | hostname [vrf vrf-name ] | VRF is optional; default-vrf is used by default. |
All these implementations use forward referencing of the VRF name in the use-vrf option, unless noted. At runtime when making the socket connection, the VRF ID by name must be resolved. If it does not resolve, it will result in a connection error.
