When creating or editing an account, you can specify when the account automatically disables after it is not used (active) for a configured period of time.
There might be instances when you would like to automatically disable an account when the account is inactive for some set period of time. Inactivity means that the account has not been used, in the recent past, to access this device. Use the acct-inactivity-expiry-period parameter to configure the number of days after which the account is automatically disabled (expires).
The root and admin accounts cannot be disabled.SNMP traps are generated for this event. For more information, see the Extreme Message Reference, 20.3.3. The traps generated are SEC-3138 and SEC-3139.
SLX # configure terminal
                SLX (config)# username aming role user password Tijdlspw acct-inactivity-expiry-period 30
