EPS-150DC External Power Module (with EPS-T2)
The EPS-150DC External Power Module (Model 10909) is a modular power supply for use in the EPS-T2 External Power System Tray.
- Summit X250e-24tDC switch
- Summit X250e-24xDC switch
- Summit X250e-48tDC switch
- Summit X450a-24tDC switch
- Summit X450a-24xDC switch
- Summit X450a-48tDC switch
When this power supply is used with one of the listed Summit switches, the internal and external power supplies are fully fault tolerant and load-sharing. If one power supply fails, the other power supply will provide sufficient power to operate the switch.
The EPS-T2 is a rack-mountable chassis or tray that holds one or two EPS-150DC power supplies. Each EPS-150DC provides one-to-one redundancy to an attached Extreme switch. You must install the EPS-150DC power supply in the EPS-T2 tray.
Power LED | Meaning |
Green, solid |
The external power module is operating normally. |
Off |
The external power module is not connected. |
For centralized DC power connection, this product is intended to be installed in restricted access locations (dedicated equipment rooms, equipment closets, or the like) in accordance with Articles 110-16, 110-17, and 110-18 of the National Electric Code, ANSI/NFPA 70.
