EPS-C2 Redundant Power System
The EPS-C2 is an external power supply system that supplies redundant power to switches.
It is a standalone unit that can be rack mounted in a regular 19-inch rack system. The EPS-C2 can be populated with up to three Summit 750 W PoE AC PSUs (power supply units) to provide a total redundant power budget of up to 2040 W. The redundant power supply system can connect up to five switches to actively provide power to all five if needed.
The EPS-C2 redundant power system consists of the EPS-C2 chassis (Model 10936) plus one, two, or three installed Summit 750 W AC power supplies (Model 10931). For more information about the 750 W AC power supply including LED meanings, see Summit 750 W AC Power Supply.
The EPS-C2 system is compatible with the following switch models:
  • Summit X250e-48p switch
  • Summit X440-8t switch
  • Summit X440-8p switch
  • Summit X440-24t switch
  • Summit X440-24t-10G switch
  • Summit X440-24t-DC switch
  • Summit X440-24p switch
  • Summit X440-24p-10G switch
  • Summit X440-24x switch
  • Summit X440-24x-10G switch
  • Summit X440-48t switch
  • Summit X440-48p switch
  • Summit X450e-48p switch
  • Summit X450-G2 series switches (all models)
The EPS-C2 system provides redundant power for up to five Summit X440 series switches or for a single Summit X450e-48p or Summit X250e-48p switch. Redundant power connectors on the rear panel of the EPS-C2 chassis are specific to the supported switch type; a selection switch toggles between the connector type. Five 2x7 connectors are used for the X440 switches, and one 2x9 connector for the other Summit switches.
The 750 W AC PoE PSU used on the EPS-C2 has two power rails: 12V and PoE. These two power rails are independent. If the PoE rail overloads, it will shut down all PoE but the 12V rail will continue to function. If the 12V rail overloads, the 12V shuts down and the PoE rail will continue to function.
One redundant 2x7 power cable is shipped with the EPS-C2 chassis to provide the connection between the external power system and the redundant power input connector on the back of a switch. Additional redundant power cables are available from Extreme Networks.
The following table lists the power capability in watts of the EPS-C2 based on the number of installed PSUs. Check the power requirements of your switches to determine how many PSUs you need to install into the EPS-C2 chassis.
  12V Power (W) PoE Power (W)
1 PSU 300 380
2 PSUs 600 760
3 PSUs 900 1140
For technical specifications, see EPS-C2 Redundant Power Supply Technical Specifications.
