Single 600-LS Module Configuration: Redundant PoE Power
A single EPS-600LS power module provides redundant PoE (Power over Ethernet) power capability with the same 370-watt capacity as the internal power supply.
The internal Summit X450e-48p or X250e-48p power supply is capable of 370 W of PoE power: 15.4 W supplied to each port for a 24-port configuration and 7.7 W supplied to each port for a 48-port configuration.
  • If the internal power supply fails, the external power module will provide power to PoE devices at the same power levels as the internal power supply without any power interruptions.
  • If the EPS-600LS power module fails or is removed, the internal power supply continues to provide PoE power without any power interruptions.
