External Power Supplies for Summit Switches
The following tables list the compatible power supply models for Summit switches that use external power supplies for redundancy.
External Power Supplies for X150 Series Switches
Switch Model Compatible External Power Supply Model: Part Number
X150-24t EPS-160 External Power Module with EPS-T EPS-160: 10907
EPS-T: 10906
X150-24x EPS-160 External Power Module with EPS-T EPS-160: 10907
EPS-T: 10906
X150-24p EPS-500 External Power Supply Unit EPS-500: 10911
X150-48t EPS-160 External Power Module with EPS-T EPS-160: 10907
EPS-T: 10906
External Power Supplies for X250e Series Switches
X250e-24t EPS-160 External Power Module with EPS-T EPS-160: 10907
EPS-T: 10906
X250e-24p EPS-500 External Power Supply Unit EPS-500: 10911
X250e-24x EPS-160 External Power Module with EPS-T EPS-160: 10907
EPS-T: 10906
X250e-48t EPS-160 External Power Module with EPS-T EPS-160: 10907
EPS-T: 10906
X250e-48p EPS-600LS External Power Module with EPS-C chassis EPS-600LS: 10913
EPS-C: 10912
750 W Power Supply with EPS-C2 chassis 750 W AC PSU: 10931
EPS-C2: 10936
External Power Supplies for X350 Series Switches
X350-24t EPS-500 External Power Supply Unit EPS-500: 10911
X350-48x EPS-500 External Power Supply Unit EPS-500: 10911
External Power Supplies for X440 Series Switches
X440-24t 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
X440-24t-10G 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
X440-L2-24t 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
X440-24p 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
X440-24p-10G 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
X440-48t 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
X440-48t-10G 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
X440-L2-48t 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
X440-48p 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
X440-48p-10G 500 W PoE+ Redundant Power Supply Unit RPS-500p: 10923
EPS-C2: 10936
External Power Supplies for X450 Series Switches
X450-24t EPS-160 External Power Module with EPS-T EPS-160: 10907
EPS-T: 10906
X450-24x EPS-160 External Power Module with EPS-T EPS-160: 10907
EPS-T: 10906
External Power Supplies for X450a Series Switches
X450a-24t EPS-LD External Power Supply Unit EPS-LD: 45019
X450a-24tDC EPS-150DC External Power Module with EPS-T2 EPS-150DC: 10909
EPS-T2: 10910
X450a-24x EPS-LD External Power Supply Unit EPS-LD: 45019
X450a-24xDC EPS-150DC External Power Module with EPS-T2 EPS-150DC: 10909
EPS-T2: 10910
X450a-48t EPS-500 External Power Supply Unit EPS-500: 10911
External Power Supplies for X450e Series Switches
X450e-24p EPS-LD External Power Supply Unit EPS-LD: 45019
X450e-48p EPS-600LS External Power Module with EPS C chassis EPS-600LS: 10913
EPS-C: 10912
EPS-C2: 10936
X450e-24t EPS-500 External Power Supply Unit EPS-500: 10911
X450e-48t EPS-500 External Power Supply Unit EPS-500: 10911
External Power Supplies for X450-G2 Series Switches
X450-G2-24t-GE4 150 W Non-PoE redundant power supply STK-RPS-150PS
EPS-C2: 10936
X450-G2-24t-10GE4 150 W Non-PoE redundant power supply STK-RPS-150PS
RPS-500p: 10923
EPS-C2: 10936
X450-G2-48t-GE4 150 W Non-PoE redundant power supply STK-RPS-150PS
RPS-500p: 10923
EPS-C2: 10936
X450-G2-48t-10GE4 150 W Non-PoE redundant power supply STK-RPS-150PS
RPS-500p: 10923
EPS-C2: 10936
Most of the switches listed in each section of this chapter run ExtremeXOS software. For information about compatible switches running ExtremeWare® software, refer to the Consolidated “i” and “e” Series Hardware Installation Guide.
