X450 and X250 PoE Redundant Power Configurations
The PoE (Power over Ethernet) capability of the Summit X450e-48p or X250e-48p varies depending on the number of external power modules in use.
The following table summarizes the PoE power behavior for the Summit X450e-48p or X250e-48p switch based on the number of power modules in use.
PoE Power Behavior
Internal Power Supply Status EPS-600LS (1x) EPS-600LS (2x) EPS-600LS (3x) External Power Supply/Chassis Failed/Disconnected
Internal Power Supply:
Power On
370 W of
redundant power
740 W of
external power only
Internal power supply disabled
740 W of
external power only with 2 + 1 redundancy
370 W of
internal power only
Power Failure
370 W of
external power only
740 W of
external power only
740 W of
No PoE power
