Summit 1100 W AC Power Supplies
Summit 1100 W AC power supplies are available in the following models:
  • 1100 W AC PSU-FB (Model 10941)—power supply with front-to-back ventilation airflow
  • 1100 W AC PSU-BF (Model 10942)—power supply with back-to-front ventilation airflow
Both power supplies are compatible with Summit X460-G2 PoE (Power over Ethernet) switch models that have the same airflow direction as the power supply.
The Summit 1100 W AC PSU-FB power supply (Model 10941) is compatible with the Summit X450-G2 PoE switch models.
The Summit 1100 W AC power supplies have a keyed power inlet (C16) that requires a notched (C15) power cord.
The Summit 1100 W AC power supplies have the status LEDs listed in Summit 1100 W AC Power Supply LED Status Indications.
IN_OK (Green) OUT_OK (Green/RED) Description
Off Off No AC input power connection or low AC voltage.
On Off AC input good, 54V output disabled.
On (Red) On AC input good, output (54V) fault.
On (Green) On AC input good, DC outputs in spec.
