Summit 300 W AC and DC Power Supplies
The following 300 W power supplies are available:
  • Summit 300 W AC power supply: front-to-back airflow (Model 10930A)
  • Summit 300 W AC power supply: back-to-front airflow (Model 10943)
  • Summit 300 W DC power supply: front-to-back airflow (Model 10933)
  • Summit 300 W DC power supply: back-to-front airflow (Model 10944)
These power supplies are compatible with the following switch models:
The Summit 300 W power supplies (AC and DC) have the status LEDs listed in the following table.
Summit 300 W Power Supply LED Status Indications
LED Label and Color Meaning
In OK
Green
Out DC OK
Green/red bicolor
Off Off No input power
Off Steady red No input power; receiving standby output from system.
On Off Input good; 12 V output is disabled. Standby output is ON.
On Steady red Input good; fault in 12 V output.
On Flashing green and red Input good, 12 V output good. Power supply alert: power supply is likely to fail because of a developing fault, such as abnormal thermal conditions or poor fan performance.
On Steady green Input good; DC outputs good.
