Summit 550 W AC and DC Power Supplies
Summit 550 W power supplies are available in the following models:
  • 550 W AC PSU-FB (Part number 10925)—AC power supply with front-to-back ventilation airflow
  • 550 W DC PSU-FB (Part number 10926)—DC power supply with front-to-back ventilation airflow
  • 550 W AC PSU-BF (Part number 10927)—AC power supply with back-to-front ventilation airflow
  • 550 W DC PSU-BF (Part number 10928)—DC power supply with back-to-front ventilation airflow
These power supplies are compatible with the following switch models:
  • Summit X670-48x switch
  • Summit X670V-48x switch
  • Summit X670-G2 switches (all models)
  • Summit X770-32q switch
The power supply must have the same airflow direction (front-to-back or back-to-front) as the switch with which it is being used. In a redundant power configuration, the airflow direction must be the same for both power supplies, and it must match the airflow direction of the fans in the switch.
The Summit 550 W power supplies (AC and DC) have the status LEDs listed in Summit 550 W Power Supply LED Status Indications.
Position Color and State Meaning
Top
Power Good
Steady Green +3.3VSB ok; 12 V ok; power supply is working properly.
Middle
Power Supply Fail
Steady Amber Fault condition (for example, 3.3VSB OCP/UCP, 12V OCP/UCP, or fan failure).
Bottom
AC OK
Steady Green Power supply is connected to power.
If the cord is connected and this LED is off, the power supply is defective.
