Summit 550 W Power Supplies for X670-G2 Switches
Summit 550 W power supplies are available in the following models:
  • 550 W AC PSU-FB (Model DS550HE-3 )—AC power supply with front-to-back ventilation airflow
  • 550 W DC PSU-FB (Model DS550DC-3)—DC power supply with front-to-back ventilation airflow
  • 550 W AC PSU-BF (Model DS550HE-3-002)—AC power supply with back-to-front ventilation airflow
  • 550 W DC PSU-BF (Model DS550DC-3-003)—DC power supply with back-to-front ventilation airflow
Specifications for 550 W Power Supplies for the X670-G2
The following tables list the specifications for the 550 W AC PSU-FB (Model 10925) and 550 W AC PSU-BF (Model 10927) AC power supplies for use in X670 and X770 series switches.
Physical Specifications
Dimensions
Height: 1.57 inches (4.0 cm)
Width: 3.07 inches (7.8 cm)
Depth: 13.31 inches (33.8 cm)
Weight
AC model 3.64 lb (1.65 kg) DC model 2.58 lb (1/17 kg)
DC Model Power Specifications
Nominal input
-48 to -60 VDC, 24 A
DC Voltage input range
-35 to -75 V
Inrush Current
21 A peak
Maximum wire size
14 AWG (1.5 mm2 copper stranded).
DC Output 12 V, 45 A/3.3V, 3A
DC Output Power (W)
550 W
Environmental Specifications
Operating temperature
0°C to 45°C (normal operation)
Storage temperature
-40°C to 70°C
Operating humidity
20% to 90% relative humidity, non-condensing
Operating altitude
Up to 10,000 feet
Operational shock
Frequency Range
5 to 350 Hz, 200 to 2000 Hz PSD: 0.0001g2/Hz
350 to 500 Hz -6dB/Octave, 500 Hz 0.000052 Hz
Acceleration
0.21.0 gRMS (Typical Level)
Duration: 20 min per axis
Summit DC Power Supplies for X670 and X770 Series Switches
The following tables list the specifications for the 550 W DC PSU-FB (Model 10926) and 550 W DC PSU-BF (Model 10928) power supplies for use with the Summit X670 and Summit X770 series switches.
Dimensions
Height: 1.5 inches (3.8 cm)
Width: 3.1 inches (7.8 cm)
Depth: 13.3 inches (33.8 cm)
Weight
3.22 lb (1.46 kg)
Nominal Input
–40 V to –60 V, 18 A
DC Voltage Input Range
–36 to –75 V ../Graphics/DC_PowerSymbol_9pt.svg
Maximum Input Amperages
18 A @ 36 V ../Graphics/DC_PowerSymbol_9pt.svg13.5 A @ 48 V ../Graphics/DC_PowerSymbol_9pt.svg
8.5 A @ 75 V ../Graphics/DC_PowerSymbol_9pt.svg
Inrush Current
25 A peak
Inrush Energy
0.625 A2S
Minimum wire size
14 AWG (1.5 mm2) copper stranded
DC Output
12 V ../Graphics/DC_PowerSymbol_9pt.svg, 45 A/3.3 V ../Graphics/DC_PowerSymbol_9pt.svg, 3.0 A
DC Output Power (W)
550 W
Storage temperature
-40°C to 70°C
Operating humidity
Operating altitude
Up to 10,000 feet
Operational shock
Frequency Range
Acceleration
