STK-RPS-150PS and RPS Shelves Technical Specifications
The Extreme Networks STK-RPS-150PS is a hot-swappable 150 watt DC power redundant power supply for use with an Extreme Networks stackable or standalone fixed switch model that does not support PoE (Power over Ethernet).
Caution
Caution
The STK-RPS-150PS does not support pliant fixed switch models. Do not connect the power cable from an STK-RPS-150PS to a PoE-compliant fixed switch. Otherwise, damage to the switch may result.
The STK-RPS-150PS can be installed as a standalone unit or with the following rack-mounted shelves:
  • STK-RPS-150CH2, a two-slot shelf
  • STK-RPS-150CH8, an eight-slot shelf
STK-RPS-150PS Specifications
Physical Specifications
Dimensions
7.7 H x 2.04 W x 10.1 D (in.)
19.6 H x 5.2 W x 25.7 D (cm)
Unpackaged Weight
3.85 lb (1.75 kg)
Power Specifications
AC input frequency range
50 to 60 Hz
AC input voltage range
100-240 VAC
Output Voltage
12VDC
Output Current
1.0 A min., 8.5 A or 13.0 A max.
Environmental Specifications
Operating temperature
0°C to 50°C (32°F to 122°F)
Storage temperature
-40°C to 70°C (32°F to 122°F)
Operating humidity
5% to 95% (non-condensing)
STK-RPS-150CH2 Specifications
Dimensions without mounting brackets
5.5 H x 44.0 W x 18.0 D (cm)
2.2 H x 17.3 W x 7.0 D (in.)
Unpackaged Weight
2.09 lb (0.95 kg)
STK-RPS-150CH8 Specifications
22.26 H x 44.0 W x 26.4 D (cm)
8.77 H x 17.3 W x 10.4 D (in.)
Unpackaged Weight
11.6 lb (5.27 kg)
STK-RPS-150PS Connector Pin Locations
../Graphics/stk_150ps_pins.png
STK-RPS-150PS Connector Pin Functions
Pin Function Pin Function
1 - 50 V return 8 Ground
2 - 50 VDC 9 No connection
3 12 VDC output 10 RPS present
4 12 VDC output 11 Status 1
5 12 VDC output 12 Status 2
6 12 VDC output 13 Power good
7 Ground 14 Ground
