Summit 300 W Power Supplies Technical Specifications
The following Summit 300 W power supplies are available for use:
  • Summit 300 W AC power supply Front-to-Back airflow Model 10930A
  • Summit 300 W AC power supply Back-to-Front airflow Model 10943
  • Summit 300 W DC power supply Front-to-Back airflow Model 10933
  • Summit 300 W DC power supply Back-to-Front airflow Model 10944
These power supplies are for use with the Summit X460-G2 series, Summit X460-24t, Summit X460-24x, Summit X460-48t, and Summit X460-48x switches.
Summit 300 W AC Power Supply (Model 10930A and 10943)
Physical Specifications
Dimensions
Height: 1.57 inches (4.0 cm)
Width: 3.15 inches (8.0 cm)
Depth: 9.5 Inches (24.1 cm)
Weight
2.25 lb (1 kg)
Power Specifications
Voltage input range
85 to 264 V../Graphics/AC_PowerSymbol_9pt.svg
Nominal input ratings
100 to 240 V../Graphics/AC_PowerSymbol_9pt.svg, 50 to 60 Hz, 5 A
Nominal input current at full loads
4.2 A @ 90 V../Graphics/AC_PowerSymbol_9pt.svg (low-line)
1.7 A @ 230 V../Graphics/AC_PowerSymbol_9pt.svg (high-line)
Line frequency range
47 to 63 Hz
Maximum inrush current
30 A
Output
12 V../Graphics/DC_PowerSymbol_9pt.svg, 25 A max, 300 Watts
3.3 V../Graphics/DC_PowerSymbol_9pt.svg, 3.03 A max, 10 Watts
Power supply input socket
IEC 320 C14
Power cord input plug
IEC 320 C13
Power cord wall plug
Refer to Power Cord Requirements for AC-Powered Switches and AC Power Supplies.
Power supply cord gauge
18 AWG (0.75 mm2) up to 6 feet or 2 meters
or
16 AWG (1.0 mm2) over 6 feet
Efficiency
Low Line: 85% at 50% load and 88% at 100% load
High Line: 86% at 50% load and 89% at 100% load
Environmental Specifications
Operating temperature
0°C to 50°C (normal operation)
Storage temperature
-40°C to 70°C
Operating humidity
20% to 90% relative humidity, non-condensing
Operational shock
30 m/s2 (3 G)
Summit 300 W DC Power Supply (Model 10933 and 10944)
Dimensions
Weight
1.83 lb (0.83 kg)
Nominal Input
–40 to –72 V, 9 A
DC Voltage Input Range
18V to -72V../Graphics/DC_PowerSymbol_9pt.svg
Maximum Input Amperages
9 A @ 40 V../Graphics/DC_PowerSymbol_9pt.svg
7.5 A @ 48 V../Graphics/DC_PowerSymbol_9pt.svg
5 A @ 72 V../Graphics/DC_PowerSymbol_9pt.svg
Inrush Current
82 A at 72 V../Graphics/DC_PowerSymbol_9pt.svg peak
Minimum wire size
14 AWG (1.5 mm2) copper stranded
DC Output
12 V../Graphics/DC_PowerSymbol_9pt.svg, 25 A/3.3 V../Graphics/DC_PowerSymbol_9pt.svg, 3.0 A
DC Output Power (W)
300 W
Storage temperature
-40°C to 70°C
Operating humidity
Operational shock
30 m/s2 (3 G)
