Summit 350 W Power Supplies Technical Specifications
The following Summit 350 W power supplies are available for use in Summit X460-G2 series PoE (Power over Ethernet) switches:
  • Summit 350 W AC power supply: front-to-back airflow (part no. 10953)
  • Summit 350 W AC power supply: back-to-front airflow (part no. 10954)
Summit 350 W AC Power Supply (10953, 10954)
Physical Specifications
Dimensions
Height: 1.57 inches (4.0 cm)
Width: 3.25 inches (8.3 cm)
Length: 10.22 inches (26.0 cm)
Weight
2.55 lb (1.12 kg)
Power Specifications
Voltage input range
100-127/200-240../Graphics/AC_PowerSymbol_9pt.svg 47 to 63Hz
Nominal input ratings
12.5 A max at 115VAC and 6A max at 230VAC at Full 350 W load
Maximum inrush current
45A at Max 264 VAC at 25C with cold start
Output
54 V, 13.2 A max, 350 W
Power supply input socket and cord
IEC/EN 60320-1/C16 AC input receptacles
Power cord wall plug
Refer to Power Cord Requirements for AC-Powered Switches and AC Power Supplies.
Efficiency
Minimum efficiency: 88% at maximum power output.
Environmental Specifications
Operating temperature
-10°C to 50°C (normal operation)
Storage temperature
-40°C to 70°C
Operating humidity
93% relative humidity, non-condensing at 30C
Operational shock
30 m/s2 (3 G)
