Summit 450 W Power Supplies Technical Specifications
The following two power supplies are available for use in the Summit X480 series switches and in Summit X670 series switches that have front-to-back ventilation airflow.
  • Summit 450 W AC power supply
  • Summit 450 W DC power supply
Summit 450 W AC Power Supplies
The following tables list the specifications of the AC power supplies for use with the Summit X480-24x, X480-48x, Summit X480-48t, Summit X670-48x, and Summit X670V-48x switches:
Physical Specifications
Dimensions
Height: 1.5 inches (3.8 cm)
Width: 3.1 inches (7.8 cm)
Depth: 13.3 inches (33.8 cm)
Weight
3.64 lb (1.65 kg)
Power Specifications
Voltage input range
90 to 264 V../Graphics/AC_PowerSymbol_9pt.svg
Nominal input ratings
100 to 240 V../Graphics/AC_PowerSymbol_9pt.svg, 50 to 60 Hz, 8 A
Nominal input current at full loads
12 A @ 90 V../Graphics/AC_PowerSymbol_9pt.svg (low-line)
5 A @ 230 V../Graphics/AC_PowerSymbol_9pt.svg (high-line)
Line frequency range
47 to 63 Hz
Maximum inrush current
15 A
Output
12 V../Graphics/DC_PowerSymbol_9pt.svg, 37 A max, 450 Watts
3.3 V../Graphics/DC_PowerSymbol_9pt.svg, 3 A max, 9.9 Watts
Maximum continuous DC output shall not exceed 450 Watts.
Power supply input socket
IEC 320 C14
Power cord input plug
IEC 320 C13
Power cord wall plug
Refer to Power Cord Requirements for AC-Powered Switches and AC Power Supplies.
Power supply cord gauge
18 AWG (0.75 mm2) up to 6 feet or 2 meters
or
16 AWG (1.0 mm2) over 6 feet
Efficiency
84% typical at full load, high line
Environmental Specifications
Operating temperature
0°C to 45°C (normal operation)
Storage temperature
-40°C to 70°C
Operating humidity
20% to 90% relative humidity, non-condensing
Operational shock
30 m/s2 (3 G)
Summit 450 W DC Power Supplies
The following tables list the specifications of the DC power supplies for use with the Summit X480-24x, X480-48x, and Summit X480-48t:
Dimensions
Weight
3.22 lb (1.46 kg)
Nominal Input
–48 to –60 V../Graphics/DC_PowerSymbol_9pt.svg, 24 A
DC Voltage Input Range
–40 to –75 V../Graphics/DC_PowerSymbol_9pt.svg
Maximum Input Amperages
13.5 A @ 40 V../Graphics/DC_PowerSymbol_9pt.svg
11.2 A @ 48 V../Graphics/DC_PowerSymbol_9pt.svg
7.5 A @ 72 V../Graphics/DC_PowerSymbol_9pt.svg
Inrush Current
10 A peak
Inrush Energy
1.5 A2S
Minimum wire size
14 AWG (1.5 mm2) copper stranded
DC Output
12 V../Graphics/DC_PowerSymbol_9pt.svg, 36.7 A/3.3 V../Graphics/DC_PowerSymbol_9pt.svg, 3.0 A
DC Output Power (W)
450 W
Storage temperature
-40°C to 70°C
Operating humidity
Operational shock
30 m/s2 (3 G)
