Summit External Power Supplies Technical Specifications
The following external power supplies are available for use with Summit X150, X250e, X450, X450a, and X450e series switches:
  • EPS-LD external power supply
  • EPS-160 external power module (used with EPS-T chassis)
  • EPS-500 external power supply
  • EPS-600LS external power module (used with EPS-C chassis)
  • EPS-150DC external power supply (used with EPS-T2 chassis)
For use with the Summit X450a-24t and X450e-24p switches
Operational voltage range
90 to 264 V../Graphics/AC_PowerSymbol_9pt.svg
Nominal input ratings
100 to 240 V../Graphics/AC_PowerSymbol_9pt.svg, 50 to 60 Hz, 10 A
Input Current
6 A at 100 V../Graphics/AC_PowerSymbol_9pt.svg, 2.5 A at 240 V../Graphics/AC_PowerSymbol_9pt.svg
Line frequency range
47 to 63 Hz
Maximum inrush current
30 A at 115 V../Graphics/AC_PowerSymbol_9pt.svg, 60 A at 230 V../Graphics/AC_PowerSymbol_9pt.svg
Output
-50 V../Graphics/DC_PowerSymbol_9pt.svg, 7.5 A max, 375 Watts
12 V../Graphics/DC_PowerSymbol_9pt.svg, 7.5 A max, 90 Watts
Power supply cord type
AC
Power supply input socket
IEC 320 C14
Power cord input plug
IEC 320 C13
Power cord wall plug
Refer to Power Cord Requirements for AC-Powered Switches and AC Power Supplies.
Power supply cord gauge
18 AWG (0.75 mm2) up to 6 feet or 2 meters
or
16 AWG (1.0 mm2) over 6 feet
Efficiency
>75% at 100% load
Heat dissipation, Watts, BTU/hr
123 W, 419.7 BTU/hr
Power consumption, Watts, BTU/hr
588 W, 2006.3 BTU/hr
Ambient operating temperature
0°C to 40°C (32°F to 104°F)
For use with the Summit X150-24t, X150-48t, X250e-24t, X250e-24x, X250e-48t, X450-24t, and X450-24x switches
100 to 250 V, 4 to 2 A, 47 to 63 Hz
47 to 63 Hz
Input current
2 A at 100 V
1 A at 240 V
Line frequency
50 to 60 Hz
30 A at 115 V../Graphics/AC_PowerSymbol_9pt.svg, 50 A at 230 V../Graphics/AC_PowerSymbol_9pt.svg
Output
12 V../Graphics/DC_PowerSymbol_9pt.svg, 11 A
5 V../Graphics/DC_PowerSymbol_9pt.svg, 1.5 A
AC
IEC 320 C14
Power supply input plug
IEC 320 C13
or
Efficiency
80% at 100% load
Heat dissipation, Watts/BTU
38.5 W, 131.4 BTU/hr
178 W, 607.4 BTU/hr
The following figure shows the wire-to-pin connections for the connector on the rear panel of the EPS-160 power supply.
Pinouts for the Redundant Power Supply Connector
Connector Pin Number Wire Label Pin Number Wire Label
../Graphics/Es4k028_Converted.svg
1
NC
8
RS+
2
GND
9
GND
3
GND
10
INT PG
4
GND
11
EXT_CON
5
GND
12
EXT_PG
6
+12 V
13
+5 V
7
+12 V
14
+12 V
For use with the Summit X150-24p, X250e-24p, X450a-24t, X450a-24x, X450a-48t, and X450e-24p switches
Nominal input current
5.75 A @ 115 V../Graphics/AC_PowerSymbol_9pt.svg (low-line)
2.80 A @ 230 V../Graphics/AC_PowerSymbol_9pt.svg (high-line)
47 to 63 Hz
30 A @ 115 V, 60 A @ 220 V../Graphics/AC_PowerSymbol_9pt.svg
Output
12 V../Graphics/DC_PowerSymbol_9pt.svg, 10.5 A max, 126 Watts
Maximum continuous DC output shall not exceed 500 Watts.
AC
IEC 320 C14
IEC 320 C13
or
Efficiency
>70% @ 100% load
158 W, 539.1 BTU/hr
659 W, 2248.6 BTU/hr
For use with the Summit X450e-48p and X250e-48p switches
Must be installed in the EPS-C chassis (Model 10912)
100-250 V../Graphics/AC_PowerSymbol_9pt.svg, 50/60 Hz, 10 A
7 A @ 115 V../Graphics/AC_PowerSymbol_9pt.svg (low-line)
3.5 A @ 230 V../Graphics/AC_PowerSymbol_9pt.svg (high-line)
47 to 63 Hz
17 A @ 115 V/60 Hz, maximum load
Output power
600 W
AC
IEC 320 C14
IEC 320 C13
or
Efficiency
85% nominal
219 W, 747.3 BTU/hr
801 W, 2733.1 BTU/hr
Output Ratings for EPS-C chassis with 1, 2, or 3 installed EPS-600LS units
One EPS-600-LS unit
582 W output: –48 V/9 A (432 W), 12 V/12.5 A
Two EPS-600-LS units
1116 W output: –48 V/18 A (864 W), 12 V/21 A
Three EPS-600-LS units
1260 W output: –48 V/21 A (1008 W), 12 V/21 A
For use with the Summit X450a-24tDC and Summit X450a-24xDC switches
–36 to –72 V../Graphics/DC_PowerSymbol_9pt.svg
–36 to –72 V../Graphics/DC_PowerSymbol_9pt.svg, 6 A maximum
Input current
5.5 A @ –36 V../Graphics/DC_PowerSymbol_9pt.svg (low-line)
2.6 A @ –72 V../Graphics/DC_PowerSymbol_9pt.svg (high-line)
47 to 63 Hz
Inrush current
20 A @ 48 V, 40 A @ 72 V../Graphics/DC_PowerSymbol_9pt.svg
Input wire harness
Extreme part number 250088-00
TYCO PN 206061-1
TYCO PN 206060-1
None provided
14 AWG (2.0 mm2)
Input wire harness
Extreme part number250088-00
Efficiency
> 75% at 100% load
45 W, 153.5 BTU/hr
195 W, 665.4 BTU/hr
0°C to 40°C
Storage and transportation temperature
–40°C to 70°C
The following figure provides the wire-to-pin connection specifications for the DC wiring harness shipped with the EPS-150DC power supply. Three-wire Cable Harness shows the connector.
Wire-to-Pin Connection Specifications
Pin Number Wire Color Circuit Connection
1
Green/yellow
Chassis ground
2
Red
Return
3
Black
-48 V
4
unused
Three-wire Wiring Harness
../Graphics/EWUG005.svg
