Summit 750 W Power Supplies Technical Specifications
The Summit 750 W AC power supply (part no. 10931) is available for use with Summit X460 series PoE (Power over Ethernet) switches. It is compatible with the EPS-C2 power supply.
The Summit 750 W AC power supply is also used in the EPS-C2 external power system.
Physical Specifications
Dimensions
Height: 1.57 inches (4.0 cm)
Width: 3.15 inches (8.0 cm)
Depth: 9.5 inches (24.1 cm)
Weight
2.25 lb (1 kg)
Power Specifications
Voltage input range
85 to 264 V ../Graphics/AC_PowerSymbol_9pt.svg
Nominal input ratings
100 to 240 V ../Graphics/AC_PowerSymbol_9pt.svg , 50 to 60 Hz, 10 A
Nominal input current at full loads
10 A at 90 V ../Graphics/AC_PowerSymbol_9pt.svg (low-line)
3.7 A at 230 V ../Graphics/AC_PowerSymbol_9pt.svg (high-line)
Line frequency range
47 to 63 Hz
Maximum inrush current
35 A
Output
12 V ../Graphics/DC_PowerSymbol_9pt.svg, 25 A max, 300 Watts
55 V ../Graphics/DC_PowerSymbol_9pt.svg, 8.18 A max, 450 Watts
3.3 V ../Graphics/DC_PowerSymbol_9pt.svg, 3.03 A max, 10 Watts
Power supply input socket
IEC 320 C14
Power cord input plug
IEC 320 C13
Power cord wall plug
Refer to Power Cord Requirements for AC-Powered Switches and AC Power Supplies.
Power supply cord gauge
18 AWG (0.75 mm2) up to 6 feet or 2 meters
or
16 AWG (1.0 mm2) over 6 feet
Efficiency
Low Line: 88% at 50% load and 86% at 100% load
High Line: 90% at 50% and 100% loads
Environmental Specifications
Operating temperature
0°C to 45°C (normal operation)
Storage temperature
-40°C to 70°C
Operating humidity
20% to 90% relative humidity, non-condensing
Operational shock
30 m/s2 (3 G)
