Power Specifications
Power Supply Options
XN-ACPWR-150W
XN-ACPWR-150W-FB
XN-ACPWR-600W
XN-ACPWR-600W-FB
XN-ACPWR-920WXN-ACPWR-1200W*
XN-ACPWR-1200W-FB
XN-ACPWR-2000W**
XN-ACPWR-2000-FB-A
Voltage Input
Range (Nominal)
100-127/200-240
VAC
100-127/200-240
VAC
100-127/200-240
VAC
100-127/200-240
VAC
100-127/200-240
VAC
Line Frequency Range47Hz to 63Hz47Hz to 63Hz47Hz to 63Hz47Hz to 63Hz47Hz to 63Hz
Power Supply Input SocketIEC/EN60320 C14IEC/EN60320 C14IEC/EN60320 C14IEC/EN60320 C16
IEC/EN 60320 C14 (for -FB)
IEC/EN60320 C16
IEC/EN 60320 C14 (for -FB-A)
Power Cord Input PlugIEC/EN60320 C13IEC/EN60320 C13IEC/EN60320 C13IEC/EN60320 C15
IEC/EN 60320 C13 (for -FB)
IEC/EN60320 C15
IEC/EN 60320 C13 (for -FB-A)
Operating Temperature
0°C to 50°C (32°F to 122°F)
Normal Operation
Normal Operation
Normal Operation
Normal Operation
0°C to 45°C
(32°F to 113°F)***
* 200-240VAC is required to achieve full 1200W output. If run at 100-120 VAC, output is limited to 860W
** 200-240 VAC is required to achieve full 2000W output. If run at 100-120 VAC, output is limited to 1100W
*** At sea-level, 0°C to 40°C (32°F to 104°F) at1500 m; 0°C to 35°C (32°F to 95°F) at3000 m
5420F Internal Fixed and Secondary Power Supply Options
ModelInternal Fixed Power Supply Unit (PSU)*Secondary Power Supply Unit (PSU)**
5420F-24T-4XE120W AC PSUXN-ACPWR-150W or XN-ACPWR-150W-FB
5420F-24P-4XE660W AC PSU XN-ACPWR-600W or XN-ACPWR-600W-FB
5420F-24S-4XE150W AC PSUXN-ACPWR-150W or XN-ACPWR-150W-FB
5420F-48T-4XE120W AC PSU XN-ACPWR-150W or XN-ACPWR-150W-FB
5420F-48P-4XE860W AC PSU XN-ACPWR-920W or XN-ACPWR-1200W-FB
5420F-48P-4XL860W AC PSUXN-ACPWR-920W or XN-ACPWR-1200W-FB
5420F-8W-16P-4XE660W AC PSUXN-ACPWR-600W or XN-ACPWR-600W-FB
5420F-16W-32P-4XE1200W AC PSUXN-ACPWR-1200W or XN-ACPWR-1200W-FB
5420F-16MW-32P-4XE1200W AC PSUXN-ACPWR-1200W or XN-ACPWR-1200W-FB
* Internal Fixed PSU is non-orderable and comes pre-installed with each 5420F model
** Secondary PSU provides power redundancy in 5420F non-PoE models and enables maximum PoE Power Budget in 5420F PoE models (see table below). Model/PSU combinations other than those listed above are blocked physically or in software.
Refer to the Hardware Installation Guide for minimum software versions needed on the switch for supported power supply units.
5420F PoE Power Budget
ModelPoE Budget with Single Internal Fixed PSUPoE Budget with Recommended Secondary PSU
5420F-24P-4XE380W 720W
5420F-48P-4XE740W 1440W
5420F-48P-4XL740W1440W
5420F-8W-16P-4XE480W 960W
5420F-16W-32P-4XE872W*/960W**1437W*/1874W**
5420F-16MW-32P-4XE860W*/960W** 1425W*/1862W**
* @ 100-120 VAC
** @ 200-240 VAC
5420M Primary and Secondary Power Supply Options
ModelPrimary Power Supply Unit (PSU)*Secondary Power Supply Unit (PSU)*
5420M-24T-4YEXN-ACPWR-150W or XN-ACPWR-150W-FBXN-ACPWR-150W or XN-ACPWR-150W-FB
5420M-24W-4YE XN-ACPWR-920W or XN-ACPWR-1200W-FBXN-ACPWR-920W or XN-ACPWR-1200W-FB
5420M-48T-4YE XN-ACPWR-150W or XN-ACPWR-150W-FBXN-ACPWR-150W or XN-ACPWR-150W-FB
5420M-48W-4YEXN-ACPWR-920W, XN-ACPWR-2000W, or XN-ACPWR-1200W-FBXN-ACPWR-920W, XN-ACPWR-2000W, or XN-ACPWR-1200W-FB, XN-ACPWR-2000W-FB-A
5420M-16MW-32P-4YE XN-ACPWR-920W, XN-ACPWR-2000W, or XN-ACPWR-1200W-FBXN-ACPWR-920W, XN-ACPWR-2000W, or XN-ACPWR-1200W-FB, XN-ACPWR-2000W-FB-A
Primary PSU is required; Secondary PSU provides power redundancy and enables maximum PoE Budget in 5420M PoE models (see table below). Model/PSU combinations other than those listed above are blocked physically or in software.
5420M PoE Power Budget
ModelPower Supply PoE Budget with Single Primary PSUPoE Budget with Optional Secondary PSU
5420M-24W-4YEXN-ACPWR-920W XN-ACPWR-1200W-FB 720W1440W
5420M-48W-4YEXN-ACPWR-920W XN-ACPWR-1200W-FB 804W1558W
XN-ACPWR-2000W XN-ACPWR-2000W-FB- A884W*/1440W** 1704W*/2880W**
5420M-16MW-32P-4YEXN-ACPWR-920W XN-ACPWR-1200W-FB787W1541W
XN-ACPWR-2000W XN-ACPWR-2000W-FB- A884W*/1440W** 1687W*/2400W**
* @ 100-120 VAC
** @ 200-240 VAC
Minimum/Maximum Power Consumption and Heat Dissipation
Table 1. 5420F Switches
Switch ModelMinimum Power Consumption (W)Minimum Heat Dissipation (BTU/hr)Maximum Power Consumption (W)*Maximum Heat Dissipation (BTU/hr)**
5420F-24T-4XE248162211
5420F-24P-4XE37127833387
5420F-24S-4XE35119114388
5420F-48T-4XE3110675255
5420F-48P-4XE481641674663
5420F-48P-4XL491681657604
5420F-8W-16P-4XE371271092452
5420F-16W-32P-4XE461562150785
5420F-16MW-32P-4XE501722152790
* Includes maximum PoE load (W) through the switch
**Does not include PoE load heat dissipated through external electronic load
Table 2. 5420M Switches
5420M-24T-4YE289557194
5420M-24W-4YE431481601551
5420M-48T-4YE3411768232
5420M-48W-4YE722453090716
5420M-16MW-32P-4YE692342564560
