Advanced Edge License Features
The Advanced Edge License includes all Edge License features and the features in the following table.
ExtremeXOS Advanced Edge License Features
ExtremeXOS Software Feature Supported Platforms
EAPS Advanced Edge (multiple physical rings) All platforms that support the Advanced Edge and Core licenses.
ERPS-more domains (allows 32 rings with matching ring ports) and multi-ring support
BlackDiamond 8000 series
Summit family switches
ESRP-Full
Summit X460, X480, X670, and X770 series switches
ESRP-Virtual MAC
OSPFv2-Edge (limited to max of 4 active interfaces) All platforms that support the Advanced Edge and Core licenses.1
OSPFv3-Edge (limited to max of 4 active interfaces) All platforms that support the Advanced Edge and Core licenses.1
PIM-SM-Edge (limited to max of 4 active interfaces) All platforms that support the Advanced Edge and Core licenses.1
VXLAN All platforms that support the Advanced Edge and Core licenses.
VRRP All platforms that support the Advanced Edge and Core licenses.1
PSTag All platforms.
