Path Selection for CSPF Computation
The selection of path for the LSP depends on whether you want to use IGP or TE metric for CSPF computation. Consider the network topology in the illustration. The ingress router is DUT 1 and the egress router is DUT 5. There are two cases depending upon whether IGP metric or TE metric is used for CSPF computation.
Path selection for CSPF computation
When IGP metric is selected
The LSP selects the following path:
When TE metric is selected
