Lightweight Directory Access Protocol (LDAP) is used in Authentication, Accounting, and Authorization (AAA) server environments that consist of a centralized authentication server and multiple Network Access Servers (NAS) or clients. With LDAP support, management of SLX devices integrates seamlessly into these environments.
Transport Layer Security (TLS) is cryptographic protocol to provide communication security between client and server applications that communicate with each other over the network.
The certificate revocation status of the LDAP over TLS (LDAPS) client can be checked using OCSP. LDAPS protects communication when it is established.
By default, LDAPS uses port 636.
Command | Function |
ldap-server host | Configures an LDAP server to connect for external or remote authentication. The ldaps option specifies that LDAP over TLS is to be used. |
crypto import | Imports the Identity Certificate for security configuration. The ldapca option specifies that LDAP over TLS is to be used. |
