Wi-Fi 6 (802.11ax) Antennas Specifications Guide Version Wi-Fi 6 11ax Antennas.
Internal Antenna Radiation Patterns
> AP460S6C Internal Antenna Radiation and Sensor Patterns
Published March 2024
Preface
External Antenna Selection and Site Preparation
Antenna Connector Types
Antenna Selection Criteria
Antenna Location Criteria
Cable Options
Antenna Cables Specifications
Antenna Compatibility Matrix
AP510C/CX and AP305C/CX Access Points Antennas Support Country List
External Antenna Connectors
External Fixed Antenna Specifications and Radiation Patterns
AP3000X Integrated Antennas
External Detachable Antenna Specifications and Radiation Patterns
ML-2452-APA2-01 and ML-2452-APA2-02 Antenna Specifications and Radiation Patterns
ML-2452-HPA5-036 Antenna Specifications and Radiation Patterns
ML-2452-HPA6-01 Antenna Specifications and Radiation Patterns
ML-2452-HPAG4A6-01 Antenna Specifications and Radiation Patterns
ML-2452-HPAG5A8-01 Antenna Specifications and Radiation Patterns
ML-2452-PTA2M2-036 Antenna Specifications and Radiation Patterns
ML-2452-PTA4M4-036 Antenna Specifications and Radiation Patterns
ML-2452-PNA5-01R Antenna Specifications and Radiation Patterns
ML-2452-SEC6M4-036 Antenna Specifications and Radiation Patterns
ML-2452-PNA7-01R Antenna Specifications and Radiation Patterns
AI-DQ04360S Antenna Specifications and Radiation Patterns
WS-AI-DQ05120 Antenna Specifications and Radiation Patterns
WS-AI-5Q04060 Antenna Specifications and Radiation Patterns
WS-AI-2Q05060 Antenna Specifications and Radiation Patterns
WS-AI-DE07025 Antenna Specifications and Radiation Patterns
WS-AI-5Q05025 Antenna Specifications and Radiation Patterns
WS-AI-DE10055 Antenna Specifications and Radiation Patterns
WS-AO-DQ05120N Antenna Specifications and Radiation Patterns
WS-AO-5Q04060N Antenna Specifications and Radiation Patterns
WS-AO-5Q05025N Antenna Specifications and Radiation Patterns
WS-AO-DQ04360N Antenna Specifications and Radiation Patterns
AH-ACC-ANT-AX-KT Antenna Specifications and Radiation Patterns
AI-DS0305360-RPSMA Antenna Specifications and Radiation Patterns
AI0-DD75060-RPSMA Antenna Specifications and Radiation Patterns
AI0-DD05120-RPSMA Antenna Specifications and Radiation Patterns
AP505i Internal Antenna Radiation Patterns
AP510i Internal Antenna Radiation Patterns
AP560i Internal Antenna Radiation Patterns
AP305C Internal Antenna Radiation Patterns
AP410C Internal Antenna Radiation Patterns
AP460C Internal Antenna Radiation Patterns
AP460S12C Internal Antenna Radiation and Sensor Patterns
AP3000 Internal Antenna Specifications and Radiation Patterns
Antenna Installation Information
Weatherproof the Antenna Connections
Drip Loop for Anenna Cables
Install the ML-2452-APA2-01 or ML-2452-APA2-02 Antenna
Install the ML-2452-HPA5-036 Antenna
Install the ML-2452-HPA6-01 Antenna
Install the ML-2452-HPAG4A6-01 Antenna
Install the ML-2452-HPAG5A8-01 Antenna
Install the ML-2452-PTA2M2-036 Antenna
Install the ML-2452-PTA4M4-036 Antenna
Install the ML-2452-PNA5-01R Antenna
Install the ML-2452-SEC6M4-036 Antenna
Install the ML-2452-PNA7-01R Antenna
Install the WS-AI-5Q0460 Antenna
Install the AI-DQ04360S Antenna
Install the WS-AI-DQ05120, WS-AI-DE07025, WS-AI-DE10055, or WS-AO-DQ05120N Antenna
Install the WS-AO-DQ04360N Antenna
Install the AH-ACC-ANT-AX-KT Antenna
Install the Antenna Using the WS-MB-WALLEXT01 Extension Bracket Kit
AP460S6C
AP460S6C
access point internal antenna radio patterns
AP460S6C
radio 0 2.4 GHz azimuth pattern
AP460S6C
radio 0 2.4 GHz elevation pattern
AP460S6C
radio 0 5 GHz azimuth pattern
AP460S6C
radio 0 5 GHz elevation pattern
AP460S6C
radio 1 5 GHz azimuth pattern
AP460S6C
radio 1 5 GHz elevation pattern
AP460S6C
access point sensor patterns
AP460S6C
AP460S6C
AP460S6C
AP460S6C
