Verify the Box Contents
The 3150C ships with everything needed for a basic installation. Confirm that you have received the following items before you install your appliance.
The power cord must be purchased separately for the respective country where you are deploying the device.
  1. Confirm that the box contains the following items:
    • One Regulatory and Compliance guide. The guide has a QR code to access the product documentation.
    • One 3150C unit.
    • One right rack-mount bracket.
    • One left rack-mount bracket.
    • Twelve screws for rack-mount brackets.
    • Four rubber feet.
  2. Inspect the appliance for any physical damage.
    Contact Extreme Networks Support Portal if there is any damage.
