Feature ID | New feature | Description |
HOS-18946 | AFC: GA Ready AFC Solution | AFC is now supported on IQ Engine specifically for the AP5050U & AP5050D. AFC support is a requirement for Standard Power use for outdoor 6 GHz radios. The AP must coordinate channel and power availability from an AFC SaaS database before transmitting. |
HOS-20824 | Thread router—Fix mdns advertisement when using non-default vlan | We resolved an issue with mDNS advertisement when using non-default VLAN. |
